If I'm thinking of the right component, you can grab a metal rod slightly smaller than the extruder and feeding it through the nozzle while it's hot.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
8 minutes ago, Hackentosher said:
Uh, can you attach some pictures? You mean it got stuck in the feeder?
Ye ill attach some
No thats the extruder your thinking of
8 minutes ago, Legolessed said:
No you cant. Ive tried both ways. Idk
What do you mean both ways? It looks like the material is being grabbed by the feeder. If you open up repetier host, can you move the feeder through that? (keep in mind printers wont move the feeder unless the hotend is at temperature.
ASU
I mean ive positioned the filament roll both ways around like you suggested. im sorry whats the repetier host? xyz has a pre determined loading sequence where the hot end heats and then it pulls the filament through. works like a charm normally but right now its not
Repetier host is a slicer and printer control software. It's pretty neat, I use it for my robotics club's printer, but I stick with Cura for my own. Anyway, use it because it will let you control all the functions of the machine manually over usb.
The thing about the filament is for when you get it feeding.
ASU
