Hey guys!!
Just wanted to know if the components in this build are compatible with each other:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-006-AR
http://www.overclockers.co.uk/showproduct.php?prodid=MB-435-GI
http://www.overclockers.co.uk/showproduct.php?prodid=CP-496-IN
any bronze rated 750W PSU
Thanks a lot !
https://linustechtips.com/topic/86357-help-with-a-new-build/
They are compatible.
The 4771 on a z87 mobo is awkward though.
What about the rest of the part? What's the system being used for?
Btw, this should be in New Builds and Planning, not Guides and Tutorials.
https://linustechtips.com/topic/86357-help-with-a-new-build/#findComment-1172463
Why the locked CPU on a chipset designed for overclocking? I'd get the 4770K and Overclock it if you intend on staying with the Z87.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/86357-help-with-a-new-build/#findComment-1172468
