EDIT: So, does anyone have a recommendation for a i5-8600k and the rest if my list?
Hiya guys. With help from a friend, I have this list for a gaming pc currently at hand:
New list: https://ca.pcpartpicker.com/list/8jYptJ
I was wondering whether you had any suggestions for it, among it the power supply. Would a 650 Gold be okay, or a EVGA 600-650 Bronze be enough?
Also, if you live in Canada, what day is the best this week for sales: Thursday afternoon, friday midnight or morning, or monday midnight or morning?
https://linustechtips.com/topic/862858-first-build/
What is your budget?
Edited by LinusTechTipsFanFromDarlo
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/862858-first-build/#findComment-10727547
https://ca.pcpartpicker.com/list/92Zg2R
Get the Coffee Lake chips if you can afford it/get your hands on it. In many applications, the i5 8600k beats the i7 7700k. May as well get the latest and greatest if you can!
https://linustechtips.com/topic/862858-first-build/#findComment-10727550
Something like this would be better...
https://ca.pcpartpicker.com/list/cKbN3F
زندگی از چراغ
https://linustechtips.com/topic/862858-first-build/#findComment-10727589
I assume that the SSD is for your OS and games correct? If it is just for the OS then you can save some money by getting a smaller SSD. Around 120GB would be fine.
Stay with the gold.
https://linustechtips.com/topic/862858-first-build/#findComment-10727590
Stay with the gold.
Yeah, just saw that gold one seemed good. Any recommendations for a SSD? The choice I had before was only 20 cheaper, so it didn't seem like that much of savings.
https://linustechtips.com/topic/862858-first-build/#findComment-10727619
Efficiency doesn't say anything about how good a PSU actually is. And EVGA has a whole lot of really bad PSUs.
550W is plenty for the build, even overclocked, and the Focus Plus Gold is available for about the same.
I hope the build was made before October 5th, because after that, it would make no sense.
For gaming, the 8400 or 8600K will match or beat the 7700K, so get one of those.
Don't get an H-series motherboard for an unlocked chip. For Coffee, you'll need a Z370 motherboard.
The MX300 has a bit more capacity than the SU800, costs a bit less, and is as good otherwise
For a gaming build, you should focus more on the GPU than on the CPU. A 1070 Ti should be doable.
But do check what comes on sale on Black Friday. If there's a better component for the same price, or a matching component at a cheaper price, you should change it.
https://linustechtips.com/topic/862858-first-build/#findComment-10727648
If it is just for the OS then you would be fine with this one:
https://ca.pcpartpicker.com/product/m34NnQ/sandisk-ssd-plus-120gb-25-solid-state-drive-sdssda-120g-g26
I know some people like to put their games on a SSD so it boots quicker. This way you can put the $20 on other things.
https://linustechtips.com/topic/862858-first-build/#findComment-10727649
there are some good SSD on sale for a bit less on Newegg.ca. you can check those out.
https://linustechtips.com/topic/862858-first-build/#findComment-10727671
Does anyone have a recommendation for a board that is compatible with the i5-8600 and the rest of my build?
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  ($334.50 @ Vuugo)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($46.75 @ Amazon Canada)
Motherboard: Asus - ROG STRIX Z370-F GAMING ATX LGA1151 Motherboard  ($231.75 @ Vuugo)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($199.99 @ Amazon Canada)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  ($99.99 @ Amazon Canada)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($78.25 @ Vuugo)
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($544.99 @ Amazon Canada)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case  ($54.99 @ Newegg Canada)
Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply  ($84.99 @ Memory Express)
Monitor: AOC - G2460PF 24.0" 1920x1080 144Hz Monitor  ($257.04 @ Amazon Canada)
Mouse: Redragon - Centrophorus M601 Wired Optical Mouse  ($17.99 @ Amazon Canada)
Total: $1951.23
Generated by PCPartPicker 2017-11-21 13:28 EST-0500
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/862858-first-build/#findComment-10727730
Storage: ADATA - Ultimate SU800 256GB 2.5" Solid State Drive  ($104.99 @ Newegg Canada)
Power Supply: EVGA - 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($99.96 @ Amazon Canada)
Total: $1971.20
Generated by PCPartPicker 2017-11-21 13:27 EST-0500
Hmm, anyway you'd recommend saving somewhat on the motherboard, whether with the case or size?
https://linustechtips.com/topic/862858-first-build/#findComment-10727739
Dropped the board down a bit but there aren't much cheaper boards that also have SLI support which would allow an upgrade in the future. If you don't care about SLI then the second option is an even cheaper board.
Motherboard: Asus - ROG Strix Z370-H Gaming ATX LGA1151 Motherboard  ($203.75 @ Vuugo)
Total: $1923.23
Generated by PCPartPicker 2017-11-21 14:30 EST-0500
Motherboard: MSI - Z370 GAMING PLUS ATX LGA1151 Motherboard  ($162.99 @ Newegg Canada)
Total: $1882.47
Generated by PCPartPicker 2017-11-21 14:31 EST-0500
Prior Build Log/PC:
https://linustechtips.com/topic/862858-first-build/#findComment-10727981
Total: $1923.23
Total: $1882.47
I don't have much know knowledge about this stuff. How much performance would SLI give me if I decide to upgrade in the future? And exactly which boards of those would support overclocking?
https://linustechtips.com/topic/862858-first-build/#findComment-10728666
It could give you a decent bump in performance, depending on the game.
All Z370 boards support overclocking so it's just if SLI support is there or not.
Prior Build Log/PC:
https://linustechtips.com/topic/862858-first-build/#findComment-10728710
If SLI is supported in a game, you usually get 30-80% better performance by adding a second card. But there is less and less support for it in newer games, meaning you'll often see 0% improvement. Also keep in mind that SLI usually increases stuttering, and has a bunch of other annoyances
https://linustechtips.com/topic/862858-first-build/#findComment-10728715
I've been updating the list, and I'm currently reconsidering the processor, between the 7600K, 7700K and 8600K. For the build I currently have, which do you think would be a good choice, considering I'm mostly going for 1080p gaming.
And if one of the former is better, any recommendations for the motherboard?
https://ca.pcpartpicker.com/product/rKx9TW/asus-strix-h270f-gaming-atx-lga1151-motherboard-strix-h270f-gaming
This was the one I was seeing, but I'm open for any suggestions.
I had been also looking for a fully modular PSU. If my build uses around 390, how much higher should the psu have, would 550 be enough, and whether bronze or gold.
https://linustechtips.com/topic/862858-first-build/#findComment-10733627
