NZXT S340 FANS LOUD?
@Dylan
hey, i recently got a s340 and the stock fans are quite loud and im wondering how to turn rpm down because in the bios it did not work much
I have an S340 and don't find the fans to be very loud at all - are you sure no cables etc are hitting the fan? Originally the label on my CPU cooler was hitting the fan blades which made a lot of noise.
Strange, mine are pretty quiet. Depending on your motherboard you should be able to go into your bios and adjust the fans.
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
i will have a look now .
i have they got down to 45% but still loud
it may
it may be my psu making the noise i dont know ;(
it may
Unplug the case fans and see if the noise stops - you'll be fine to run for 5-10 minutes without case fans (probably a lot longer, but I wouldn't like to recommend that!)
Are fans plugged into mobo or fan hub?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
mobo
12 minutes ago, @Dylan said:
mobo
Older MSI mobos aren't that nice to 3pin fans. You can try with Speedfan to lower fan speeds even more.
okay i will check now thanks for the help
7 hours ago, @Dylan said:
mobo
What motherboard and which headers?
3 hours ago, @Dylan said:
msi p81m-p33  and the system fan ones
Sysfan2 is just a powered header that offers no form of control but sysfan1 might work for 3pin fans. Are the fans in different headers running at the same speed?
yes
On 11/22/2017 at 2:48 PM, @Dylan said:
yes
In that case, the sysfan1 header only provides 4pin pwm which means 100% rpm for 3pin fans. If you want to run the case fans at a lower rpm, you can get a fan controller or do a simple 5v mod for the molex fan adapter that comes with the case for ~40% speed. http://www.silentpcreview.com/article6-page1.html
Here's video on how it's done:
