Need help deciding!
Go to solution Solved by Snedz1989,
Decided to go for the gtx 1060 3gb. Maybe 6gb depending on black friday pricing. In the middle of  renovating my house and xmas coming up for the kid,  so while budget isn't totally tight every little helps.
Like to think im right when i say the 1060 will do for a few months till i get cash together for a more extreme build.
Thanks for all the suggestions.
Finally building a new for the first time since 2010.......
Cpu: r5 1600
Motherboard: Asus Prime B350-PLUS AMD DDR4 S-ATA 600 ATX
Psu: evga 650w gq gold
Ram: 16gb(2×8gb) corsair vengeance
Gpu:????????
Cannot decide which gpu to get. Stuck between:
Gtx 1060 3gb
Gtx 1060 6gb
Gtx 970
Rx 570
Rx 580
Gtx 1070
I only game at 1080p, only need 60 fps. Prefer a little more to help with fps drops and such. Would also like max settings when practical.
Would a 1070 be overkill for 1080p??
Same question for rx 580.
And the 970 would be used, good/bad idra buying used?
https://linustechtips.com/topic/862717-need-help-deciding/
Depends how much you want to max out the settings, realistic speaking even the GTX 1050 Ti can run 4k fine enough in a lot of games if you throw settings all the way down, it is a matter of how much tweaking with settings you're willing to do, if you want to run games max out at 1080p even the 1070 isn't enough in some titles truth be told.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/862717-need-help-deciding/#findComment-10726349
the 1060 3gb is basically a 970 give or take, so if you can find a new 1060, the 970 can be off the table, I personally use a 970 for 1080p, high with some aa.
1070 would be a safer bet since this is a new build.
Personally I think the 1060 3gb is the best choice listed
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/862717-need-help-deciding/#findComment-10726382
Cpu: r5 1600
Gpu:????????
Gtx 1060 3gb
Gtx 1060 6gb
Gtx 970
Rx 570
Rx 580
Gtx 1070
A 1050ti could easily handle most AAA games at 1080p med/high settings, 60fps. It can even run @4K, if you lower the settings a little bit. The RX 5000 series cards are inflated in price at the moment due to cryptocurrency, or you can get one at a good price with the black friday sale coming up soon. The 1060 3/6GB models are good 1080p cards, (they even do well at 1440p), there is only a 10% performance difference between the two cards, Nvidia basically disabled 10% of the CUDA cores on the 3GB model and downclocked the clockspeeds a little, depending upon the games you play, having the extra VRAM is a nice to have. A 1070 is way overkill if your only gaming at 1080p, the 1070 is made for handling higher resolutions such as 1440p->4K, so a 1060 should be enough for your use case.
https://linustechtips.com/topic/862717-need-help-deciding/#findComment-10726429
Would buying used be a good or bad idea?
If you found a decent deal on a gtx 980ti (they typically go for around $300 give or take, prices do alter). When overclocked, they perform better then a gtx 1070 but at stock speeds, the 1070 is better.
https://linustechtips.com/topic/862717-need-help-deciding/#findComment-10726432
16 minutes ago, Snedz1989 said:
One more question. Should i stick with the 1600 or go for 1600x??
1600, and u get to use the stock fan too, u can oc to 3.6/3.7 no problems with the stock fan.
https://linustechtips.com/topic/862717-need-help-deciding/#findComment-10726577
9 minutes ago, Snedz1989 said:
Could i oc higher, to 4ghz or around there?
Most people can get to 3.8/9 GHz. I got mine to 3.9 at 1.35v with the stock cooler.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/862717-need-help-deciding/#findComment-10726904
https://linustechtips.com/topic/862717-need-help-deciding/#findComment-10727768
