Im not asking for help how to pirate I already did that.
OK so I finally got a MacOS 10.12 VM going in Vmware Pro. Couple of questions:
1. How can I get it to use my GPU not shit onboard graphics? Its really laggy and not up to apples quality.
2. How do I change the resolution?
Breaking things 1 day at a time
https://linustechtips.com/topic/861575-help-with-macos-vm/
All that stuff has to be handled inside VMware.
I don't know anything about the program but I do know you need drivers for whatever GPU you have. Apple uses a select line of AMD GPUs and the Nvidia Drivers are crap for macOS.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/861575-help-with-macos-vm/#findComment-10715864
ok
https://linustechtips.com/topic/861575-help-with-macos-vm/#findComment-10715867
I think this falls under Hackintosh which is against the Community Standards. I know there’s VMware Tools for MacOS. It’s available from many YouTube videos. Google Cat and Andrew. They’re videos are really helpful. Otherwise we can’t help. Oh, and one thing, the graphics acceleration will never work right. It simply doesn’t work in a VM.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/861575-help-with-macos-vm/#findComment-10715884
Ok. I didnt think it would because im just trying to get stuff working better in a VM but if a mod knows then he can lock it or something.
https://linustechtips.com/topic/861575-help-with-macos-vm/#findComment-10715893
Unless you’re making the VM on an Apple computer, I think it is. You can send me a message about MacOS VM stuff, I’ve messed with it quite a lot.
Main System: Phobos
https://linustechtips.com/topic/861575-help-with-macos-vm/#findComment-10715943
7 hours ago, leadeater said:
Apple's ToS state you have to run Mac OS on Apple hardware, so if you're virtualizing on Apple hardware then that is fine.
But I think it's clear that you're not, correct?  I see no mac in your specs, and the fact you had to "pirate" Mac OS tells me you don't have a real mac.
https://linustechtips.com/topic/861575-help-with-macos-vm/#findComment-10718924
Guest
