Hi guys I have narrowed my choices of a case down to these 3 options:
1. http://www.amazon.com/Corsair-Obsidian-Series-Computer-CC650DW-1/dp/B004UE1W9K/ref=sr_1_1?ie=UTF8&qid=1386546015&sr=8-1&keywords=corsair+650d
2. http://www.amazon.com/Cooler-Master-HAF-XM-Computer/dp/B00BCXF6H6/ref=sr_1_3?ie=UTF8&qid=1386539806&sr=8-3&keywords=haf+X
3. http://www.newegg.com/Product/Product.aspx?Item=N82E16811146144
(Or if you have a better option for around the prices of these cases please suggest them!)
I'm just putting in average things in case so pretty much I just need some opinions. Thanks for reading and respond with your opinions! Thank you.
https://linustechtips.com/topic/86072-help-choosing-a-case-please/
Sorry....but I have too
Fractal R4
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
I'd say shell out 10 more dollars and get a 750D, beautiful case with TONS of expandibility and options
Specs: CPU: FX 8350 MOBO: Crosshair V Formula-Z RAM: 2x4GB Kingston HyperX Beast 1600Mhz GPU: Gigabyte GTX 780 Windforce GHz Edition PSU: Corsair CX750M Case: Corsair 750D Storage: Corsair Neutron GTX 120GB + WD 2TB Green + WD 200GB Black (non-functional/to take up space) Monitor: ASUS PB238Q Upgrade Plans Herehttp://pcpartpicker.com/user/chipsndip104/saved/3AAt
Corsair 650D
Rig CPU Intel i5 3570K at 4.2 GHz - MB MSI Z77A-GD55 - RAM Kingston 8GB 1600 mhz - GPU XFX 7870 Double D - Keyboard Logitech G710+
Case Corsair 600T - Storage Intel 330 120GB, WD Blue 1TB - CPU Cooler Noctua NH-D14 - Displays Dell U2312HM, Asus VS228, Acer AL1715
a friend has the switch but i had bad experience with nzxt so i'd take corsair for the looks.
        wow... pretty empty here...
For performance:
NZXT Phantom 530.
Corsair Carbide Air 540.
Cooler Master Storm Stryker
For silence:
Nanoxia Deep Silence 1
Fractal Design Define XL R2
NZXT H630
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
Out of those 3 the 650D definitely, but the R4 is amazing in that price range.
"Her tsundere ratio is 8:2. So don't think you could see her dere side so easily."
Planing to make you debut here on the forums? Read Me First!
unofficial LTT Anime Club Heaven Society
I like the size an dlook of the switch 810 and if you want to watercool it's an amazing case for it. The 650D has that Corsair name to it and almost full metal build. The coolermaster HAF series I personally don't like because i'I've seen to many of them and not much can be done in terms of watercooling with them really.
Thank you for the opinions. I think im leaning toward the 650D (I would choose 750D, but it seems to be sold out everywhere I look.) I planning to sleeve my psu and i found this sleeving color do you all think this will be a good match with the 650D? http://www.amazon.com/mod-smart-Professional-System-Sleeving/dp/B008SDS42M/ref=sr_1_32?ie=UTF8&qid=1386540136&sr=8-32&keywords=sleeving
If you're not doing anything special, why not go matx with the 350D?
Id say that two very reliable options are the Fractal Design r4 and the corsair 650D. They are both very durable mid towers with awesome air flow and good customizable feautures. One thing that the r4 may have over the 650D is the silencing foam on the inside that helps reduce noise while keeping good temperatures.
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
