I used mayhems lime green pastel concentrate and it's starting to create a brown residue.
It's been in use for almost 10 months, not heavily used but I guess it's about time to drain and refill.
I thought I wanted a pastel but after getting it I just want to go back to transparent. I feel like if I'm going to use pastel I might as well just get non transparent colored tubes.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/860042-what-coolant-to-use/#findComment-10700891
yeah it ends up being the more sensible solution since you're sure you won't get any sort of problems from it
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/860042-what-coolant-to-use/#findComment-10700912
1 hour ago, Dreaper said:
I want white and i know i might start a firestorm with this but what should i get? Pastel or no?
As mentioned before there will be the rare case of the fluid clogging or causing problem but with a properly designed loop with no dead zones in general you will have no issues. What are your watercooling components your planning to have in the loop.
https://linustechtips.com/topic/860042-what-coolant-to-use/#findComment-10701096
Everything in the p360 kit but with hardline, 1080 ti geforce block and backplate, and havent decided on fittings yet
https://linustechtips.com/topic/860042-what-coolant-to-use/#findComment-10701220
