It should work with Windows 10.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/859820-controller-and-pc/#findComment-10698414
7 minutes ago, Sukhman said:
Yes with a micro USB wire
Or a wireless adapter if you really hate cables.
CPU: Ryzen 5 3600X            | Cooler: Deepcool AK400  | Motherboard: B550 Elite AX V2  | Storage: Samsung 980 Pro 1TB  |
RAM: Corsair Vengeance 16GB   | GPU: MSI RTX 3060 Ti    | Case: NZXT H440 (Red/Black)    | PSU: EVGA 650W G2             |
https://linustechtips.com/topic/859820-controller-and-pc/#findComment-10698494
1 minute ago, kerradeph said:
My understanding is that it'll work over bluetooth too.
Yeah, if you have a second generation Xbox One controller, it will connect via bluetooth as well.
https://linustechtips.com/topic/859820-controller-and-pc/#findComment-10698512
43 minutes ago, Jacksongosnell4256 said:
Can I connect an Xbox one controller to a PC
Yes, the drivers and everything are built into Windows 10, you shouldn't have any issues. I had some issues connection my wireless Xbox 360 controller, but that was after the Xbox One controller was the standard and Microsoft changed some things with the pre-loaded drivers.
It should be plug and play for you.
https://linustechtips.com/topic/859820-controller-and-pc/#findComment-10698563
yeah you can I use one of the wireless dongles to do so when I play driving games.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/859820-controller-and-pc/#findComment-10698591
2 minutes ago, Jacksongosnell4256 said:
Since y'all are all saying windows 10 I have windows 8 so I don't think it work
It will, you just can't use bluetooth then, assuming you're PC has bluetooth and you have a second gen controller.
The Full Pounder Korbger (main PC):
CPU: AMD Ryzen 5 7600X | CPU Cooler: Deepcool AK500 ZERO DARK | MOBO: Gigabyte B650M AORUS ELITE AX | RAM: G.Skill Flare X5 32GB DDR5-5600 | Storage: Kingston NV2 1TB NVMe SSD, 2x Inland Professional 1TB SATA SSDs | GPU: ASRock Challenger Radeon RX 9070 | Case: Fractal Design North | PSU: Montech CENTURY II 850W 80+ Gold
Sheer Will and Spite (home server):
CPU: AMD A10-7870K | CPU Cooler: Stock AMD Cooler | MOBO: ASRock FM2A88X PRO3+ | RAM: Crucial 16GB DDR3-1600 | Storage: Kingston SSDNow S50 16GB SSD, Crucial MX100 512GB SSD, Seagate BarraCuda 2TB HDD, Western Digital Blue 2TB HDD, Seagate BarraCuda 1TB HDD, Seagate 1TB hybrid drive | GPU: Sparkle ECO Arc A310 | Case: Apevia X-Plorer | PSU: Thermaltake Smart Pro RGB 750W 80+ Bronze | Expansion Card: VOGZONE 2.5Gb PCIe Network Card
The Curb Stomp Coin-Op (MAME Machine):
CPU: AMD Ryzen 5 1600 | CPU Cooler: AMD Wraith SPIRE | MOBO: Gigabyte GA-AB350N-Gaming WIFI | RAM: Patriot Signature Premium 16GB DDR4-2666 | Storage: PNY CS900 240GB SSD, Samsung 860 Evo 2TB SSD | GPU: Gigabyte GeForce GTX 1050 Ti | Case: Homemade Arcade Cabinet | PSU: Corsair RM750x 750W 80+ Gold | Monitor: ONN 21.5" 1080p 100Hz Freesync
Bazzite Box (HTPC):
CPU: AMD Ryzen 5 3600X | CPU Cooler: Wraith Spire | MOBO: ASRock AB350 Gaming-ITX/ac | RAM: Corsair Vengeance RGB 16GB DDR4-3000 | Storage: WD Black SN770 1TB NVMe SSD | GPU: PowerColor Fighter Radeon RX 6600 XT | Case: PowerTrain X-GAMER X100 | PSU: MSI MAG A650BN 650W 80+ Bronze
https://linustechtips.com/topic/859820-controller-and-pc/#findComment-10698616
You only have the xbox controller one? maybe buy a sony ps3 controller that's cheap nowadays and those bluetooth usb connectors that are compatible for it in wireless, it is a lot easier than it seems.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/859820-controller-and-pc/#findComment-10698619
Windows 10 is designed to be plug and play with the Xbox one controller. Don't know about Windows 8, I'm surprised somebody wants to use it. I found the metro view horrible. If it doesn't connect after just plugging it in with usb, you probably need some kind of drivers.
My stuff:
CPU :  Intel i5 8400 | GPU : MSI GTX 970 Gaming 4GB
RAM : 32GB Corsair Vengeance DDR4 @ 3600MHz
Mouse : Logitech G502 HERO SE | Keyboard : Mountain Everest Max w/ Cherry MX Brown
Headset : Beyerdynamics DT990 Pro 250Ω w/ AT2020USB+
Monitor : Acer XF240H @  144Hz
https://linustechtips.com/topic/859820-controller-and-pc/#findComment-10699387
For my XBox One controller it was Plug and Play for Window 10.
For Windows 7, drivers were required to be installed manually (there are posts for this, you can google it).
Haven't tried it Windows 8 though, but if it's working with 7, then should work with 8 too
Finally got PS4 Pro
https://linustechtips.com/topic/859820-controller-and-pc/#findComment-10702610
