Im havinh troubles with my new pc
Cpu: I9 7840XE 18core
Motherboard: asus extreme rampage iv extended
Gpu: 2x asus 1080ti strix
Harddisk: m.2 1tb from samsung
Ram: 32 gb
But every time i boot the pc up with both gpus the pc freezes but they both work if they are running alone how can can this be??
https://linustechtips.com/topic/858288-need-help/
Both with enough power?  You should install the drivers first before trying SLI.
Desktop benching:
https://linustechtips.com/topic/858288-need-help/#findComment-10682912
  • 4 weeks later...
Cpu: i7980XE
Motherboard:Asus Rampage VI Extreme
Gpu: 1080ti in 2way sli
Ram:32 gb
Psu:1000 watt plat
Problem:
Then i slam both of them in my pc in sli it just freezes in windows but then i take one out i can play a litte but after a little time it freezes again
Help help
https://linustechtips.com/topic/858288-need-help/#findComment-10806492
have you installed all latest drivers?
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/858288-need-help/#findComment-10806509
Overclocked?
Desktop benching:
https://linustechtips.com/topic/858288-need-help/#findComment-10806532
1 hour ago, Ksanslev said:
Cpu: i7980XE
Ram:32 gb
Psu:1000 watt plat
Problem:
Help help
  • Update your Drivers
  • Update your BIOS
Come back with results :)
Desktop:
AMD Ryzen 7 @ 3.9ghz 1.35v w/ Noctua NH-D15 SE AM4 Edition
ASUS STRIX X370-F GAMING Motherboard
ASUS STRIX Radeon RX 5700XT
Corsair Vengeance LPX 16GB (2x 8GB) DDR4 3200
Samsung 960 EVO 500GB NVME
2x4TB Seagate Barracuda HDDs
Corsair RM850X
Be Quiet Silent Base 800
Elgato HD60 Pro
Sceptre C305B-200UN Ultra Wide 2560x1080 200hz Monitor
Logitech G910 Orion Spectrum Keyboard
Logitech G903 Mouse
Oculus Rift CV1 w/ 3 Sensors + Earphones
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
Crucial Ballistix Sport LT 16GB (2x 8GB) DDR4 2666
Geforce GTX 1050ti 4GB
Intel 600p 256GB NVME
Seagate Firecuda 2TB SSHD
Logitech G502 Proteus Spectrum
https://linustechtips.com/topic/858288-need-help/#findComment-10806668
Cpu: i7980XE
Ram:32 gb
Psu:1000 watt plat
Problem:
Help help
Update Drivers.
Update BIOS.
My personal PC:
CPU: Intel - Core i5 8600k  Cooler: CoolerMaster Hyper 212 Evo  Motherboard: Asus Prime Z370-P RAM: Corsair Vengeance LPX 2x8GB 3000MHz DDR4 Storage: San Disk SSD Plus 240 GB + WD Caviar Blue 1TB  Video Card: Gigabyte GTX 1070 Windforce OC 8GB Case: Phanteks Eclipse P400S Tempered Glass ATX  PSU: Corsair CX550M 80+ Bronze Certified Semi Modular PSU.
Peripherals:
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse Keyboard: Rii - RK100 Wired Standard Keyboard Monitor: Asus - VG248QE 24.0" 1920x1080 144Hz Monitor Headset: Logitech - G430 7.1 Channel Headset Speakers: Logitech - Z150 0W 2ch Speakers
Laptop:
Medion  E6239 MD99452
PCPartpicker Link:
https://uk.pcpartpicker.com/list/VVwvHN
https://linustechtips.com/topic/858288-need-help/#findComment-10806698
- Topics Merged -
Please do not re-post the same topic.
@Ksanslev it would appear you have been give some advice from both a month ago and recently to update your Drivers.
  • Have you updated your grapics drivers?
    • What were the results?
    • good, bad or no change?
  • Have you updated your BIOS?
    • Sometimes a bios update will fix a possible comparability issue with your SLI setup.
  • Have you checked to see if you motherboar supports SLI natively?
    • If it does updating the BIOS may help.
    • If it does not any updates you apply may not work unless said BIOS receives a change to allow support.
    • Checking the Manufacturers website will help shed light on this.
  • Have you attempted to install the cards in another system to see if you get the same results as you are getting in this system?
Please provide the community with more information so that other members may assist you in finding a solution.
Edited by SansVarnic
 CHRISTIAN MEMBER
https://linustechtips.com/topic/858288-need-help/#findComment-10806930
