http://www.corsair.com/en-us/vengeance-led-16gb-2-x-8gb-ddr4-dram-3000mhz-c15-memory-kit-white-led-cmu16gx4m2c3000c15
thats the memory i have and it wont work with my asus b350 strix f motherboard i have the latest bios on it but still wont got past 2133mhz but if i use my ballistix elite 8gb kit and it will do 2666mhz no problem i tried manual overclocking and xmp or docc still wont work any thoughts
http://www.crucial.com/usa/en/ble2k4g4d26afea that the ballistix memory
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/
IIRC it's a pretty well known issue with some of the LED modules, can't remember why exactly right now. If xmp and manual input of timings doesn't help then I can't think of anything left to do... I'm assuming those modules weren't on the QVL?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10680646
If you've done the usual troubleshooting and still can't get beyond 2133, RMA then do your homework before purchasing again. Ryzen is a pain in the ass with memory compatibility. Look into memory kits containing Samsung B-Die chips. They'll be more expensive, but nearly guaranteed to work.
However, if you want to double check.. make sure you're putting the ram into the correct board slots, A2 B2. Try increasing DRAM Votlage to a maximum of 1.40v. Try increasing VDDCR SOC Voltage to 1.1v (no higher than 1.2). Manually change the frequency and timings to 2666 18-18-18-36. Try changing Command Rate from 1T to 2T.
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10680700
13 hours ago, Coaxialgamer said:
Try increasing SOC voltage , and give memory 1.35V
Yep...this. I would put even 1.4v on the ram voltage (its safe), and soc at 1.15 and try...if it works, you can than either fine tune your soc and ram voltage, or if its working abd stable, just leave it as it is (again its OK).
Just don't mix the voltages of the two, that could cause problems ;).
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10682691
I always promote people to just buy a Ryzen certified kit.
Sure, it costs a little more, but at least you are guaranteed.
That's what I did below in my signature.
I know Trident Z can hit 3200mhz, if you are looking for LED RAM.
Desktop:
AMD Ryzen 7 @ 3.9ghz 1.35v w/ Noctua NH-D15 SE AM4 Edition
ASUS STRIX X370-F GAMING Motherboard
ASUS STRIX Radeon RX 5700XT
Corsair Vengeance LPX 16GB (2x 8GB) DDR4 3200
Samsung 960 EVO 500GB NVME
2x4TB Seagate Barracuda HDDs
Corsair RM850X
Be Quiet Silent Base 800
Elgato HD60 Pro
Sceptre C305B-200UN Ultra Wide 2560x1080 200hz Monitor
Logitech G910 Orion Spectrum Keyboard
Logitech G903 Mouse
Oculus Rift CV1 w/ 3 Sensors + Earphones
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
Crucial Ballistix Sport LT 16GB (2x 8GB) DDR4 2666
Geforce GTX 1050ti 4GB
Intel 600p 256GB NVME
Seagate Firecuda 2TB SSHD
Logitech G502 Proteus Spectrum
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10682752
I am an asshole. I love to push things far and get juicy scores, i should've bought Flare X. Now, the kit i have costs the same as Flare-X cost back then.
B-Die is much better performing memory.
Even on Intel boards, the Hynix AFR has issues with high speed.
Don't buy Apple M1 computers with 8GB of RAM
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10682888
3 minutes ago, dave_k said:
Then again Intel memory controllers will make good use of even shitty Hynix modules, I always like saying if you're not savvy enough to research the best but still wants the best performance just go Intel.
AMD Ryzen to work at its peak requires too much details to be filled in that if you're not willing to pay attention to those just go Intel or at least be aware your Ryzen might not work at its full potential.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10682902
Intel bias over 9000 right there
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10682910
...? I thought you knew me better than that, what is it with you lately being so rough at me? gosh sorry I'll not quote/tag you again.
Personal Desktop":
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10682970
Hynix AFR is sluggish on Intel too, the border is higher than on Ryzen (Ryzen - AFR like 2933, B-Die like 3200 Intel - AFR 3466, B-Die 4000, you get the idea), but it still lacks behind.
Saying that Intel IMC will make a good use of crappy memory is not really precise.
Look at Skylake-X, you need to mess with crap like Mesh frequency., so the easy performance isnt always true, with Ryzen/THRP you just OC your CPU and memory and are good to go.
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10682986
9 minutes ago, dave_k said:
Your interpretation of what I wrote was entirely shifted towards trying bash me, which made no sense all I said was that Intel's IMC is superior to Ryzen's, so far nothing but the true, maybe simplistic statement but i was never going deep in here any ways.
Then I said that even Hynix modules will be better used on Intel thanks to it which also is true (in no moment I ever said any thing about not needing the S.B-Die).
Then I finished stating that between an Intel mainstream like Kaby or Coffee Lake compared to AMD Ryzen you can get superior performance at the expense of less hassle, which is true, realistic speaking in the future you can pair the i7 8700 on a h310 with ANY 2666mhz stick of ram and it'll work as good as to superior than a Ryzen 7 with only premium parts, this is no making little deal of Ryzen and its place at all, just a simplistic fact.
I wrap up by mentioning it how if you're not the kind of savvy person who can't get bothered to learn the best pairings, the right motherboards the right memory and yet you want your rig working to its full potential you're better with Intel.
Now how the hell this line of thought makes me Intel biased? For crying out loud you know I have a Ryzen 7 1800x at home.
If I offended you before reason why you're locking your mind in stuff to go against me every time then I am sorry for it really am, and I said I will avoid quoting or tagging you now on as I was simply mistaken to think we were friendly contacts in here that used to help each other to state the right ways to those in need, never expected this salt from you.
Farewell.
Personal Desktop":
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10683011
Yes, that is very true
That is also pretty true
I have seen you recommending Intel quite a lot recently, even in situations where Ryzen would be better option.
I am sorry for saying that you are biased, but seriously, overclocking on Intel is as difficult as Ryzen, both platforms have different focus points, memory with Ryzen, delidding and cooling on Intel.
Edit: for the motherboard part, Coffee lake motherboard choices are even narrower than on AM4, both 8600K and 8700K are hungry bastards and require a decent board
Edited by dave_k
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10683048
Yes I have returned to recommend Intel more again with Coffee Lake (THANKS TO AMD xD for finally raising up the core count to mainstrem) might have been a bit pushy though.
It's okay as far as it goes I'm totally "cool & forgiving" and I agree that overclocking both the CPU and RAM is not that straight forwards regardless the platform, we just had a bad communication I'd say so lets bury this here and move on as friendlies ^^
Personal Desktop":
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10683061
Yes
In other words: screw intel for torturing poor consumers with 4 core chips for a helluva long time xD
honestly, i wouldnt go Intel just for the ethical reasons
Edited by dave_k
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10683065
2 hours ago, dave_k said:
Yes
One of the guys I work with is strictly AMD because he likes to feed competition.
That is the one thing that I feel that a lot of members on this forum do not understand, is that Coffee Lake is thanks to AMD Ryzen.
If anyone thinks that Intel was planning on giving an 80-90C 6C/12T trip to the mainstream platform, which I still argue cannibalizes the X299 big time, as part of their road map, they are crazy.
Coffee Lake is the undisputed performance desktop part right now, but it wouldn't exist in its current form if it wasn't for the new competition from AMD.
Unless everyone here was happy with the zero performance gains going from Sky Lake to Kaby Lake, which I think was such a BS release outside of giving 4K DRM certified iGPUs to the laptop space.
Now I just want Intel to start giving out more than 16 PCIE lanes to the mainstream!
Desktop:
Corsair RM850X
Elgato HD60 Pro
Logitech G903 Mouse
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
https://linustechtips.com/topic/858039-ddr4-ryzen-issue/#findComment-10683635
