Hi,
i am looking to upgrade my gtx 970, and i having hard time to decide if i want AIO 1080 (evga hybrid) or Air Cool one.
i never had water cooled part and i am a bit nervous (leaks etc), i will appreciate your thought on what i should get?
main use for gpu is gaming in 1440p 144hz and video encoding.
System:
CPU: Core i7 4790k
MotherBoard: gigabyte z97mx-gaming 5
Memory: 32 gigabyte ddr3 1600
GPU: gtx 970
PSU: Antec vp600p 600w
Storage: crucial ssd 525gb & 3TB Hard drive
https://linustechtips.com/topic/857540-aio-or-air/
for CPUs its an extremely easy win for air in most cases, but for GPUs its a bit harder, but i would probably go for an air cooled card and grab a G12 and a cheap AIO that fits it rather then buying a directly AIO cooled card
Builds:
https://linustechtips.com/topic/857540-aio-or-air/#findComment-10675937
Depends on the aio itself. If its a single 120 Id go air ifthe case can keep up and you play with head phones. If youre gonna put a 240 on it id go aio.
https://linustechtips.com/topic/857540-aio-or-air/#findComment-10676229
