Note : updates on rig in posts #19 and #56
Final rig in post #68
Hi,
I'm looking to invest in a first LTC mining rig and I want to know if these components are a good choice at this point in time (and space). What would be my mining performance ? How can I find how does that translate into payout. I just signed up to wemineltc.com.
PCPartPicker part list: http://ca.pcpartpicker.com/p/2gB47
CPU: AMD FX-4100 3.6GHz Quad-Core Processor  ($94.99 @ Newegg Canada)
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler  ($24.79 @ DirectCanada)
Motherboard: Gigabyte GA-990FXA-UD7 ATX AM3+ Motherboard  ($196.50 @ Vuugo)
Memory: G.Skill Ripjaws X Series 4GB (2 x 2GB) DDR3-1333 Memory  ($58.48 @ Newegg Canada)
Storage: Western Digital Red 1TB 3.5" 5400RPM Internal Hard Drive  ($77.75 @ Vuugo)
Video Card: Sapphire Radeon R9 280X 3GB Video Card (4-Way CrossFire)  ($340.00 @ Vuugo)
Power Supply: Antec 1300W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($319.00 @ Vuugo)
Total: $2131.51
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-12-07 15:26 EST-0500)
Thanks for the input,
https://linustechtips.com/topic/85534-first-ltc-rig/
you better get 7950s for cheaper!
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1162596
To my surprise, they aren't cheaper !
yeah lol, i just saw that! Dafuq is wrong with you muricans? ;)
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1162625
But 280x/7970 is better, no?
yeah, its
280x=7970>7950
But a few weeks back the 7950 was like 200-250$ so thats surprising ^^
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1162640
Thoughts about mobo, psu, ram ?
yeah, the FX4100 is a FM2 cpu and you have a am3+ socket mobo there. you only need like a crappy dual core cpu and a nice mobo with 4 pcie slots. also 2gb of ram should be enough. also, your hard drive is way to much. psu is good.
EDIT: sorry, im retarded, your cpu is am3+ m(
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1162656
i recommend something like an AMD A4 APU which is about $55 CAN.
edit:  APUs are good because you can plug the monitor into that while the cards are mining and experience no lag if you have to do other tasks
Main rig: i7 3770K @ 4.54, Sapphire R9 290, Sabertooth Z77, 16 GB Mushkin Redline 2133, Lian Li PC-P50R, Seasonic 860xp Platinum, Kingston Hyper X 3K 240GB
freeNAS server: AMD Athlon II 170u 20W, 5 x 3TB WD Red in raid-z1 (12 TB)
media centre: AMD A10-5700, crucial M4 (boot), running XBMC,4 x 3TB WD Red, 3 x 3TB WD green + 2TB green in FlexRAID (17 TB)
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1162672
Can't find a FM2 mobo with 4 x16 lanes.
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1162684
1- It's pretty much the same price for 2 sticks of ram, I'll check again
2- As for the HDD, I wanted a NAS rated drive since it's going to be on 24/7 and that one is kind of the cheapest.
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1162688
You don't need 4X16 lanes, you can use the risers that convert 16x to 1x because mining only requires that little portion of the card.
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1162704
Oh! Thanks for the info! Any particular recommandation?
I got my risers from here: http://www.hashratestore.com/shop/
And they're based in Canada too!
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1162731
Looks good.  I haven't had any issues with MSI or ASUS on the FM2 platform when it comes to mining
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1162802
Updated list :
CPU:  AMD A4-4000 3.0GHz Dual-Core Processor  ($46.50 @ Vuugo)
Motherboard:  MSI FM2-A85XA-G65 ATX FM2 Motherboard  ($104.99 @ Memory Express)
Memory:  Kingston 2GB (1 x 2GB) DDR3-1333 Memory  ($25.50 @ Vuugo)
Video Card:  Sapphire Radeon R9 280X 3GB Video Card (2-Way CrossFire)  ($343.63 @ Newegg Canada)
Total: $1285.79
(Generated by PCPartPicker 2013-12-07 16:21 EST-0500)
add to that 2x r9 280x (2x 343.63$)
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1162824
@Virgule
Heh, might use something like this as a basis for my own miner!
except for dual CF, not quad.
Great thread!
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1162826
Updated list :
Total: $1285.79
Looks pretty solid.  You don't need a 3rd party CPU cooler, the stock is fine as the APU/CPU doesn't do anything really, mine never reach 35 C.  You also don't need to put the cards in crossfire.  One minor issue is that there is a vast shortage of R9 280x in North America right now.
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1162920
Noted.
What do you mean, " you don't need to put the cards in crossfire" ?
https://linustechtips.com/topic/85534-first-ltc-rig/#findComment-1163125
