soo im looking in to water cooling my two gtx 660's
im looking in to buyinh two nzxt kraken g10's and two corsair h50's
qustion one would it be cheaper to custom loop
and would my case support it and if not what case would
I did a thing once and it was awsome: https://soundcloud.com/jamese666/junkhead-cover-with-vocals
https://linustechtips.com/topic/85502-best-gpu-water-cooling-option/
the only reason to do what your planning is if your also planning on getting 2 new nextgen cards when they come out and you want to space out your expenses.
also, if you want to know if it'd fit, it's helpful to know what case you have.
