there's a problem with my CPU I have a ryzen 5 1600 and the core frequencies are all over the place anytime I try to load into a game I get a black screen and a crash however if I have tabs up in front of the game while it's playing so that I cant see the game that will give me an extra 30 seconds before it crashes I am noticing that the voltages are changing a lot due to the change in frequency it goes in between 0.8 and 1.3 volts id really appreciate the help I've been at this all day but I've had no luck
https://linustechtips.com/topic/854031-help-my-pc-is-haunted/
ur stupid its not ghosts. i have no experience in this but im guessing a bad driver or bad software. i doubt it hardware issue.
https://linustechtips.com/topic/854031-help-my-pc-is-haunted/#findComment-10637634
I'd suggest resetting the CMOS, then doing the overclock through the BIOS. Ryzen Master is... not the best
Frostbite (White build PC)
MSI B350M Mortar Arctic - Ryzen 5 1600 @ 3.9 GHz - Corsair H60 - ASUS GTX 1060 3GB DUAL OC @ (2130 MHz Core Clock + 4600 MHz Mem Clock)
2x8GB 3200MHz Corsair Vengeance C16 Corsair 400C White - EVGA 650 GQ
  Razer Deathadder Chroma - Razer Blackwidow Tournament Edition Chroma - Sennheiser HD 598 SR - LG 24MP59G-P
https://linustechtips.com/topic/854031-help-my-pc-is-haunted/#findComment-10637686
