So I'm going for my first build and I want to know if I picked alright stuff and if I should revise anything. My budget is >$1000 without peripherals. I plan on using this just for gaming and light video editing in the future.
v v v v Here's the (original) part list. v v v v
https://pcpartpicker.com/list/YT4pf8
v v v v updated part list v v v v
https://pcpartpicker.com/list/rHgPRG
The only concern I have with this list is whether or not the stock cooler that the 1600 comes with is sufficient. I don't plan on doing any overclocking.
Edited by NoodleArmedMelvin
https://linustechtips.com/topic/853982-first-pc-build/
Yea your all good but a recommendation would be to get a 1050ti instead of that 1060 3GB or go for the 6GB version if you can afford. I say this because ice heard its not worth the extra 50 dollars for the 3gb modle of the 1060 rather than the 1050ti
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10637039
Just now, NoodleArmedMelvin said:
So I'm going for my first build and I want to know if I picked alright stuff or if I should revise anything. My budget is >$1000 without peripherals. I plan on getting one 1080p monitor and a cheap gaming mouse and keyboard.
v v v v Here's the part list. v v v v
Let me help you out brb.
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10637079
psu is eh, mobo is eh, and you should try to get an ssd.
For PSU I recommend a corsair cx/cxm grey sticker unit, and for mobo look for ones like the pro4, prime plus, and b350 f gaming.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10637097
https://pcpartpicker.com/list/ZPFPRG
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10637118
1 minute ago, Killstreak said:
This is way more expensive though.
1 minute ago, Brooksie359 said:
https://pcpartpicker.com/list/bkJwRG if you can afford it I would go with this. It's not too much more expensive than your current build plan but should have much better performance overall
1600+mobo without vrm heatsinks isn't the best idea, and psu is eh.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10637135
2 hours ago, Brooksie359 said:
The psu is honestly fine. But yeah didn't see the no vrm heatsink.
It's lacking some protections.
It's not horrible, but it's not great either.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10638098
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($193.67 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($73.98 @ Newegg)
Memory: G.Skill - Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory  ($149.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($78.99 @ SuperBiiz)
Storage: Toshiba - P300 1TB 3.5" 7200RPM Internal Hard Drive  ($40.49 @ Amazon)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB GAMING Video Card  ($259.88 @ OutletPC)
Case: NZXT - S340 (Black) ATX Mid Tower Case  ($64.99 @ SuperBiiz)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($43.98 @ Newegg)
Total: $905.97
Generated by PCPartPicker 2017-11-01 22:05 EDT-0400
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10639097
yeah it'd probably be better to save in other areas of the build besides the cpu and video card. Thanks for the reply.
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10639261
1 minute ago, NoodleArmedMelvin said:
Yeah I don't really know the difference between m.2 memory and 2.5" so I just went with one.
just different form factors, m.2 is only faster if the SSD used supports NVMe protocols.
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10639278
Thanks for your help. I really don't want to go over $1000 because I still need to get a monitor but I would rather invest more in better parts than go for the super cheap options so that they'll be better for longer. What I want is to build this and not have to change anything out for at least a few years. That being said I don't care about aesthetics and I'm not going for top of the line stuff.
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10639289
The cooler is good enough to overclock with so it should be more than fine at stock clocks.
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10639846
Alright thanks. In your opinion is it worth the extra $$$ to get the 1600x. In which case I'd also have to buy a cooler.
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10639850
You would be better off doing a slight oc of the 1600. You should be able to overclock it to the 1600x clock speeds with the cooler it comes with. I mean my 1700 overclocked to 3.7 on all cores on a crap board with a super low voltage of 1.25v
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10639856
The only thing about your updated list I would change is the psu to something like this. Everything else is great!
https://pcpartpicker.com/product/3hkwrH/corsair-power-supply-cp9020102na
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10640710
Looks good, you haven't stated what games / programs you will be running?
My Rig  ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
CPU: AMD Ryzen 5600 GPU:  ARock B580 Challenger 12GB PSU: Novatech Powerstation V2 550w Semi Modular
Mobo: Asus ROG Strix B450-F Gaming RAM: Adata XPG 16GB 3000mhz Storage: Sandisk Ultra 120GB SSD + 1 WD 1TB Blue + NVME 1TB Kingston
Case: Corsair Carbide Spec 05   Cooling:  AMD Raith Spectre RGB  Monitor:  Dell 27 Gaming Monitor G2722HS
Keyboard: Logitech G810 Orion SPECTRUM  Mouse: Logitech G502 Proteus SPECTRUM
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10640917
Do you want to overclock? @NoodleArmedMelvi
Former Bronze Contributor
CPU: Intel i7-7700K 4.2 GHz / CPU Cooler: Cryorig H7  / Board: ASRock Z270 Taichi / GPU: Nvidia 1060 6gb EVGA SC / GPU Cooler: NZXT Kraken G12 with Thermaltake Water 3.0 120mm RAM: White Corsair Vengeance LPX 16GB DDR4 2666 MHz SSD: 2x Samsung 850 Evo 250 and 3TB WD blue HDD / PSU: Corasir 550cx / Case: NZXT s340 Elite White
Im a super Italian. Kapish.
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10641340
https://pcpartpicker.com/list/23RgkT If you dont want to overclock
https://linustechtips.com/topic/853982-first-pc-build/#findComment-10641350
