Hi, what tools to use or how to find out what is slowing down SSD?
I have MB: GA-Z77-D3H and Kingston SSDNow v+200 120GB. They are connected through SATA 3 (this mother board has only two) and using SATA3 6GB cable (not that the cable matters too much). This should give reasonable read or write around 400+Mb from what I saw around or with similar systems.
Unfortunately, my seq is providing 200mb read and 100mb write.
Can you point me to right direction where the bottleneck can be?
https://linustechtips.com/topic/853479-ssd-speed/
What software are you using to test it with? Try running CrystalDiskMark and posting a screenshot of results here.
https://crystalmark.info/software/CrystalDiskMark/index-e.html
https://linustechtips.com/topic/853479-ssd-speed/#findComment-10631404
I have the same problem. It boots alot faster than my HDD, but has nearly the same write speeds.
CPU: Ryzen 5 1600 MOBO: MSI Tomahawk B350 GPU: Reference cooled GTX 980 Storage: Intel SSD5 256Gb RAM: 8gb Geil EVO Potenza Case:  Phanteks p300 PSU: EVGA 500 watt CPU Cooler: AMD wraith spire
Steam: maxarooni4
Battle.net: MAX
If you have an Oculus HMU in dead and buried
https://linustechtips.com/topic/853479-ssd-speed/#findComment-10631412
That is what I was using:
CrystalDiskMark 5.2.2 x64 (C) 2007-2017 hiyohiyo
                           Crystal Dew World : http://crystalmark.info/
* MB/s = 1,000,000 bytes/s [SATA/600 = 600,000,000 bytes/s]
* KB = 1000 bytes, KiB = 1024 bytes
   Sequential Read (Q= 32,T= 1) :   215.435 MB/s
  Sequential Write (Q= 32,T= 1) :   110.332 MB/s
  Random Read 4KiB (Q= 32,T= 1) :   138.889 MB/s [ 33908.4 IOPS]
 Random Write 4KiB (Q= 32,T= 1) :    86.885 MB/s [ 21212.2 IOPS]
         Sequential Read (T= 1) :   207.010 MB/s
        Sequential Write (T= 1) :    99.407 MB/s
   Random Read 4KiB (Q= 1,T= 1) :    22.570 MB/s [  5510.3 IOPS]
  Random Write 4KiB (Q= 1,T= 1) :    63.797 MB/s [ 15575.4 IOPS]
  Test : 50 MiB [C: 52.5% (58.2/110.8 GiB)] (x1)  [Interval=5 sec]
  Date : 2017/10/31 18:10:50
    OS : Windows 10 Professional [10.0 Build 15063] (x64)
https://linustechtips.com/topic/853479-ssd-speed/#findComment-10631451
