Sim card problem PLS HELP
Solved by minibois,
The standard is usually 0000, otherwise you changed it.
You can contact the service provider and they will likely ask for your PUK code.
kerriya ·
Posted in Cases and Mods7 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
bill well ·
Posted in Peripherals1 -
4
2
play_circle_filled
Latest From ShortCircuit:
