I got a razer deathadder elite 8-10 months ago, now it is having issues, for starters the right click will go in and out in games, normally right clicking will work, but if I hold it down it won't respond properly, like if I'm aiming down sights on a game it goes in and out after 10-20 seconds it either gives up or finally holds it down. secondly, i think I reset the mouse (has nothing to do with right click issue) lights won't respond either will DPI, I've tried random combinations it won't undo this, I've uninstalled all my drivers for my mouse reinstalled them, unplugged the mouse, tried different USB, even wait 5 mins in case it was overheating somehow, none of this works, I've looked at the tight right click space, there's nothing under it and clicks feel normal.
https://linustechtips.com/topic/852767-razer-deathadder-elite-having-issues/
1-2 year lifetime is not rare with razer
CPU: Intel i7 6700K 4.5 ghz / CPU Cooler: Corsair H100i V2 / Board: Asus Z170-A / GPU: Asus Rog Strix GTX 1070 8GB / RAM: Corsair Vengeance LPX 16GB DDR4 3000 mhz / SSD: Samsung 850 Evo 500 GB / PSU: Corsair RMx 850w / Case: Fractal Design Define S / Keyboard: Corsair MX Silent / Mouse: Logitech G403 / Monitor: Dell 27" TN 1ms 1440p/144hz Gsync
my razer mice have lived well past 5 years. most of the issues with them come from synapse. it's so trash it only ever works 30min past when you put the settings in. until reboot maybe if you're lucky. then it just breaks the tracking to the point it's impossible to even play with the mouse or the mouse stops working altogether unless re-plugged in.
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
I'm on the Deathadder Chroma for coming on 4 years now and its been going solid, Unfortunately with ANY brand out there stuff breaks,
Where you buy it from, should still fall under warranty so I'd get get a replacement like that. Best thing is get Video of it not working will just make the process go faster if they struggle to replicate it in the workshop.
I had the same issue with my Deathadder 3.5G way back when, but I kept'd throwing that one around whenever I got rekted in CS:GO, fun times.
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
i bought a Razer Deathadder Chroma 2014 edition, brand new on 24 November 2015 and at the beginning of this year the end of the usb plays up now. if it moves even slightly it drops all input, but doesn't lose power cos the LED's are still on. and it has to either be wiggled back in place or unplugged and re plugged i 50 times for it to recognize.
System 1        System 2
Intel core 2 Duo T5800 @2.00GHz                                                    Intel core i5-4460 @3.20GHz quad core
4gb RAM        8gb Samsung DDR3 1600Mhz
ATI Mobility Radeon HD 3470                                                            Nvidia Geforce GTX 660 2gb
Windows vista Home premium 32-Bit                                                Windows 7 home premium 64-Bit
(Laptop)        Asrock H81m DGS Micro ATX
System 3        System 4
Intel core i7 6700HQ up to 3.5GHz 6MB Cache                                Intel core i7 6700k @4.20GHz
Nvidia Geforce GTX 970M 3gb                                                          32gb DDR4 G.Skill ripjaws 2233Mhz
Samsung 256GB M.2 NGFF Solid State Drive                                  Gigabyte G1 Geforce GTX 980Ti
1TB 5400RPM Hard Drive        Corsair RM-750 750W 80+ Gold
16GB Dual Channel DDR3L at 2133MHz                                          Gigabyte H170 HD3 LGA1151
15.6 inch FHD (1920 x 1080) IPS Anti-Glare 220-nits Display           Intel SSD 535 Series 240GB
Windows 10 Pro        SanDisk 120GB SSD Plus
8-cell Lithium Ion (92 Whr) Battery                                                     Windows 8.1 Pro 64Bit
(Laptop)        IN-WIN GRone ATX Full Tower
        4g Arctic Cooling MX-2
        Coolermaster Hyper 103
        TP-Link TL-WN881ND
2 hours ago, Lucky5 said:
so it's potentially a dead mouse? any good replacements? I have fairly big hands, maybe slightly bigger than the deathadder would be nice, also I don't need more than 6000-8000dpi
6000-8000? That seems abnormally high, do you mean 600-800? For mouse recommendations, I have an EC2A and it works amazing, for bigger hands get an EC2B, it's a bigger and newer version of the EC2A with a 3360 sensor.
