HELP! RX480 ISSUES
Solved by iRileyx,
Check that your radeon is the most up to date. 10.7.3 is the most current, if that's what it's on, might be worth going back to the previous driver version.
Have you changed where you monitor is plugged into your PC?
6
porina ·
Posted in New Builds and Planning12 -
Rothinsky ·
Posted in Troubleshooting2 -
skayqz ·
Posted in Graphics Cards7 -
Ricodotsh ·
Posted in New Builds and Planning15 -
5
diamondx12 ·
Posted in Networking4
