As title says,
Is it normal to use a qdc as a drain valve? Or just get a regular drain valve like this? I know it has to be connected for fluid to run (which is how I want it). I wanted to drain the loop as fast as possible without unscrewing a fitting, etc. Does it lessen water flow more than a normal drain valve? I hope my drawing makes a better understanding of my question.
BTW I'm copyrighting my art if anyone dares to use it xD xD xDxD
https://linustechtips.com/topic/852231-qdc-as-drain-valve/
thats a good idea. I just broke up the IN tube with a QDC and disconnect it when draining.
Intel i7 6700k|Asus Maximus VIII Hero|Asus Strix 1080|Gskill DDR4 3200|950 Pro M.2|Corsair RM750|Corsair OBSIDIAN 500D|Corsair K65\G65|SteelSeries Arctis 5|Asus PB277Q|PG279Q
https://linustechtips.com/topic/852231-qdc-as-drain-valve/#findComment-10618818
16 minutes ago, Khris said:
As title says,
Yes it can be done as long as you have an extra quick disconnect to hookup to drain the fluid.
https://linustechtips.com/topic/852231-qdc-as-drain-valve/#findComment-10618841
well i just remove my ball valve when i want to drain, the flow throught it is so poor that it just takes too long xD this seems to me like a good idea tho
Builds:
https://linustechtips.com/topic/852231-qdc-as-drain-valve/#findComment-10618884
22 minutes ago, Khris said:
do you think using qdc will make the loop drain slower or nah?
not in any amount that matters.
https://linustechtips.com/topic/852231-qdc-as-drain-valve/#findComment-10618899
