Power-line Ethernet Adapter slow speeds
Saddy
Hello, I recently moved my power-line ethernet adapter, and now my ethernet speeds have dropped by over 6 times. (WHAT I AM USING). I have tried what tech support said, but there support is horrid and I won't get another response for days. If anyone knows how to fix this it would be appreciated.
I am also getting this error when I use Windows Network Diagnostics
Thank you for your help
If this post solved your problem, please press the check below :).
Ensure that it is plugged directly into the wall, hope this helps. Thats what happened with mine. Or reset the Powerline altogether:D .
Just found some guide saying how to fix it. Restarting my pc now to see if it works or not. Right now, it is plugged into a gigabit ethernet switch, would that be a problem?
The video did not fix it ^^
The switch shouldn't be an issue unless all devices connected are gobbling up a good chunk of your speed.
It might be the adapter itself, I don't see a lot of positive reviews on it =/
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
OK, I will try moving it directly to the wall. I have had the adapter for a while now, and it was working perfect until now.
Powerline relies on your wall outlets connecting to each other as directly as possible. Wall outlets can have a lot of weird wiring, so it can take a lot of trial and error to get them connected properly. I don't know much about that error in particular, but it could come from connecting so slow it can't read all the data it needs for handshakes.To fix this I would suggest trying test plugging it in to all the wall sockets you can.
