Stock fans a bit too loud on idle
Solved by Connor Price,
1 hour ago, sniip said:looking at what is now that one fan is 2x faster than another I want them to spin at the same RPM. I will probably place them both for intake and lower their RPM so they wouldn't be so audible and buy a PWM fan for the rear. Thanks for help.
I'm controlling 3 fans off one header with a Y splitter, and 2 fans off another header with a Y splitter. Unless you're using some very voltage hungry fans, you'll be fine.
