Best air cooler?
Go to solution Solved by WoodenMarker,
6 minutes ago, IO Studios said:
I am looking for a higher OC, I am probably also going to delid.
The only heatsink upgrade I'm seeing that would fit and is reasonably priced is the NH-U12S. https://ca.pcpartpicker.com/product/wjmLrH/noctua-cpu-cooler-nhu12s
It's not a big upgrade though.
Scythe's Fuma and Mugen 5 are good alternatives if you can find them on sale.
A MasterLiquid Pro would be a bigger upgrade but might not fit depending on your motherboard: https://ca.pcpartpicker.com/product/z9Z2FT/cooler-master-masterliquid-240-667-cfm-liquid-cpu-cooler-mlx-d24m-a20pw-r1
Unless you absolutely need the upgrade, I'd recommend just sticking with the H7. You should already squeeze most of the chips performance with delidding.
Hi,
I am currently running an i7-7700k overclocked to 4.8GHz with a cryorig H7.
I want to improve temps though, whats the best air cooler I can get?
I'm looking for something around 100$CAD. Not one of noctuas crappy looking
brown CPU coolers though. Any suggestions? Also, how much of a temp improvement
do you think ill get?
Thanks guys :)
https://linustechtips.com/topic/851824-best-air-cooler/
phanteks big air cooler is pretty decent, practically identical to noctuas nh-d14 but with nicer colors
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/851824-best-air-cooler/#findComment-10615256
Noctua has introduced some alternate colors in their fan lines, though it would mean buying another fan... Noctua is the leader in air cooling.
http://noctua.at/en/products/product-line-chromax
I have a cue light I can use to show you when I’m joking, if you like.
https://linustechtips.com/topic/851824-best-air-cooler/#findComment-10616207
What case and ram do you have?
What are your temps?
https://linustechtips.com/topic/851824-best-air-cooler/#findComment-10616634
Ballistix Sport LT 16GB Single DDR4 2400 MT/s
Corsair Carbide Series 100R Case
I7-7700k Overclocked to 4.8GHz max load temp is 75C
75c is perfectly fine. Are you looking to push for a higher oc? Is your current cooler too noisy?
https://linustechtips.com/topic/851824-best-air-cooler/#findComment-10616674
https://linustechtips.com/topic/851824-best-air-cooler/#findComment-10616726
Okay thanks man, I'm going to stick with the h7 and just delid then! That was a lot of helpful information! :D
Have a good day :)
https://linustechtips.com/topic/851824-best-air-cooler/#findComment-10616762
i will say Noctua NH-U14S
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/851824-best-air-cooler/#findComment-10617455
It's too tall for the case.
https://linustechtips.com/topic/851824-best-air-cooler/#findComment-10620230
didn't know the case sorry
My head on 2019 :
https://linustechtips.com/topic/851824-best-air-cooler/#findComment-10620786
