500mbps: Ethernet cable VS Wireless 5GHz
2 hours ago, noobs guid to marsterrace said:I've used bought a there's a massive difference
10 hours ago, krishna1997 said:there won't be noticable difference both wired and wirelss will be same
On 2017-10-26 at 12:42 AM, Tsuki said:thats actually the exact one that im using
and i just have the antenna stuck to the front of my case.
On 2017-10-25 at 9:11 AM, jakemaster1390 said:In that case as long as you have an AC wifi card with an AC access point with a short wired connection to the modem that has external antennas (then you can set up a better coverage area by being able to manioulate them) then go ahead and get the fibre connection as ac will be able to take better advantage of the speed coming an as long as you are not hitting a latency above good rule of thumb of 50 ms then you should be fine for gaming. also with having good line of sight you should not experience an issue.
Oh and if nails are a no no for getting an ethernet cord over doorways then maybe consider hanging the cable with those command hooks at least rated for 2 pounds. I use them all the time and have never had them damage the paint on the walls but have bought too light of adhesive ones and had them fall off.
On 2017-10-25 at 8:25 AM, ArduinoBen said:I'd pick the first one.
On 2017-10-25 at 7:19 AM, noobs guid to marsterrace said:With wifi you will get higher ping witch is bad in games but if that isn't your primary concern then
On 2017-10-25 at 7:19 AM, Tsuki said:i play on wifi (802.11 ac 5GHz) , with a floor between me and the router.
i honestly dont have any issues that i wouldnt have already had on a wired connection.
the biggest difference is going to be a slight increase in latency, unless you're streaming.
even torrenting i didnt notice a major decrease.
as long as you have a stable connection, its not a big deal
On 2017-10-25 at 7:15 AM, SquintyG33Rs said:wifi is always less reliable. if you're doing multiplayer gaming it's going to be annoying, and there's no avoiding it. watching videos and live-streams or downloads won't show much of a difference between the two though.
Hi there you all!
Thanks a lot to everyone for take the time reading and answering ^^.
In the end I got the Asus PCE-AC68 and guess what.... WORKS GREAT.
I pay for 500mbps connection and I'm receiving 99% of the connection wireless
