It should fit...
You should check first if you have a 6-pin connector tho. If you don't you can get a better PSU or use a molex to 6-pin adapter, not ideal but should work.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/850270-will-it-fit/#findComment-10597836
Assuming you have that Medion prebuilt, just take a tape measure and measure out if the card physically fits
According to MSI the dimensions are 229 x 131 x 39 mm
Then check the wattage of your PSU (there should be a label on the side) and check if it has one of these connectors:
https://linustechtips.com/topic/850270-will-it-fit/#findComment-10598408
The GPU would fit, but I can't find the cables, I forgot to check the label.
https://linustechtips.com/topic/850270-will-it-fit/#findComment-10601221
In that case you would also need a new Power Supply. Adapters exist but I wouldn't really recommend that.
https://linustechtips.com/topic/850270-will-it-fit/#findComment-10605663
Nvm, I already found out the solution, you just need to put it in the motherboard since it will provide enough power, thanks for the help tho, btw the powersupply is build in so I can't do that.
https://linustechtips.com/topic/850270-will-it-fit/#findComment-10605722
Yeah the 1050ti requires no external power. I misread that as 1060. Or did you edit your post? I could have sworn it said 1060 since I also looked up the dimensions of an MSI 1060. :D
https://linustechtips.com/topic/850270-will-it-fit/#findComment-10605737
Nope, lol, 1050 ti gaming x 4g is good enough for what I do.
https://linustechtips.com/topic/850270-will-it-fit/#findComment-10611046
18 hours ago, chilicheeseburger said:
Then you have nothing to worry about as long as it physically fits.
There's more than enough space for it, so I'm happy, it's saving so much money lol, and it also gives me a better pc way quicker, would take me months to get 700 euros for a good pc.
https://linustechtips.com/topic/850270-will-it-fit/#findComment-10614401
Wait! I just looked at the 1050 ti gaming from gigabyte and saw that thing has 3 hdmi, would be awesome since i can have multiple monitors connected with hdmi then...
But does that one do need a connector or does it also just works like, just put it in the motherboard and it works.?
https://linustechtips.com/topic/850270-will-it-fit/#findComment-10617558
Do you mean the gaming g1?
That will need a 6pin power connector.
You can always look up the specs on the manufacturer's homepage.
https://linustechtips.com/topic/850270-will-it-fit/#findComment-10617903
I'm hearing people say that the one from msi does need one and the one from gigabyte doesn't, i'm confused right now....
https://linustechtips.com/topic/850270-will-it-fit/#findComment-10618010
