Get a scarlett interface, the best audio quality.
https://linustechtips.com/topic/850149-usb-audio-interface/#findComment-10596534
I have the 202HD and I've been happy with it so far. For around $50 I don't think there is a lot to complain about. The build quality is pretty decent for the price and the phantom power seems to work fine. Out of all the budget USB interfaces, the one you chose is the one I would get. Mine is just a slightly older model of the one you are looking at if I remember correctly.
CPU: Intel Core i7 8700k 3.7Ghz MOBO: AsRock Z370 Extreme4
RAM: Corsair Vengeance (4x4) Storage: Crucial MX300 275Gb | WD Blue 1Tb
GPU: XFX RS RX480 8Gb Case: Corsair 270R PSU: Seasonic Focus+ 750w
Monitors: HP 22cwa | BenQ BL2420PT  Cans: ATH-M50x
https://linustechtips.com/topic/850149-usb-audio-interface/#findComment-10596606
4 minutes ago, SirWolf said:
So if i buy a umc22 the quality will be even better.
No. What you're spending more on is the extra features and better design, rather than a "much better" pre-amp or ADC.
At the price you're looking at those behringer models are the best bet.
https://linustechtips.com/topic/850149-usb-audio-interface/#findComment-10598265
I've read on some forum that the pre amps are better than in the umc2 and its worth the extra money. I dont mind giving a little more money for the umc22 and getting a slight better audio. Also the um2 is kinda "funky" and the umc22 looks way more cleaner. These are some aspects which i take in count.
https://linustechtips.com/topic/850149-usb-audio-interface/#findComment-10598284
Have you turned phantom power on for the mic (switch on the back of the interface)?
Use the windows recording devices as a visual aid, turn the gain for the mic up (knob on the front of the interface [Gain 1]) until your normal talking voice fills approx. 4/5ths of the VU bars.
https://linustechtips.com/topic/850149-usb-audio-interface/#findComment-10641982
