Here soon with my tax return I plan on buying a good DSLR camera. Being new to the operation of DSLR's I'm not sure what to be looking for or what makes one better than the next. I know I want to be able to change lenses but not much other than that. I know Nikon and Canon are great brands and am leaning towards one of those. I'm looking to spend in the range of $500-$800. Any recommendations?
https://linustechtips.com/topic/850001-dslr-beginner-recomendations/
D5600?
ive only used canon products so my recommendations will reflect that
the cheapest SL2 or T6i /T7i  (or whatever "T" model is current now) is a really good place to start
SL2 has good reviews
i started with a T2i 7 years ago and it has been extremely solid - and still works perfectly
Photography / Finance / Gaming
42 minutes ago, Dietrick_K said:
What would classify good DSLR vs. a bad one? I know there is a lot but I guess what is the biggest things that matter.
Well, the sensor is probably the most important thing.  Look for high resolution and good low-light performance.  Of course to get the most out of either, but particularly the former, you will want a good quality lens as well.  Also make sure it has a wide dynamic range, this will really help capture landscapes where the sky is bright and ad risk of being blown out while the ground is often comparatively dark.
Other than that, people tend to look for max shooting speed (how many full normal images it can take per second) which will be somewhere in the range of 3 (low) to 10+ (good for action), as well as buffer size, which will affect low long you can shoot at this rate continuously before dropping to a much slower rate that depends on how fast your SD card is.
Another important thing is the auto-focus system.  How many points are there, how much of the frame do they cover, how well does it track moving objects, etc.
Is there a point where the MegaPix become irrelivent and it would be more on the lens for better performance? For example I am looking at the Canon Rebel T6 with a 18-55mm and 75-300mm lens. This one is an 18 meg but I have seen them go as high as 24+
Absolutely, but that relationship isn't easy to explain, since (Among other things) it depends on the lens you're looking at.  Basically consider the MP of the camera the maximum theoretical MP you can ever get, and any lens you use is going to get you somewhere between maybe ~25% and up to maybe ~99% of that, depending how bad/good it is.  If you can, check DXOMark for your camera and lens combination and they will tell you roughly how sharp it is in "P-MPix".
4 minutes ago, L.Lawliet said:
The color depth,processor,fps ( this is subjective ) ,low light performance,comfort,and sensor..
Dont go to crazy over ISO performance though..cause it could be some manufacturer tricks like FUJI used to do and still do perhaps :P
Because In general ISO performance in DSLR will double every 8 Years and DSLR just been around recently..
My recommendation is Canon T3i/T5i for photography..
And Panasonic G7 (Mirrorless) for Videography..yes i know its mirrorless.
I recommend that because it can shoot up to 24fps at 4k.
With DSLR if u want to shot 4k u'll gonna need to spend $1000 camera like 1D mark iii..
Luckily I don't really plan on doing videography with the camera since I already have a camcorder and GoPro to do that.
P-MPix I am guessing is a ratio of lens proformance to MP output?
It's how many "perceptual MP" the images is.  So, for example, if you take a 1000 x 1000 image and stretch it up to 6000 x 4000, the file is now 24 MP but there's still only 1 MP worth of detail there.  Because you'll never get an infinitely sharp, perfect lens, the true amount of detail in your image will always be somewhat less than the sensor can capture, and how much less depends on the lens quality.
For example, a crappy lens on a 24 MP camera might give 9 or 10 P-MPix, but a great lens might get up to over 22
When looking at these cameras I keep seeing shutter speeds that are confusing. For example 1/4000-30 sec. not exactly sure what this means. FYI this is for the canon t6i
that means it can be as quick as 1/4000 of a second (probably fine but not the best - many will do 1/8000) or as slow as 30 seconds.  If you are interested in long exposure shots, you will want to make sure it also offers "bulb", which means it stays open as long as you hold it, or better yet, a mode whee you click once to open and once more to close so you don't have to stand there xD although, in the case of the last thing I said, there are often remotes and other external controls you can get to add this
I take it this would greatly benefit action shots or anything with quick movements. But if I was to look for color capture, without needing a ton of computer work, what would I be looking for on a camera, as in what spec do I look at?
Well, colour gamut and/or bit depth I suppose... tbh I'm not sure, it's not something I've ever considered.  Afaik any current DSLR will be good enough in both those aspects to not have any issues in that regard.  It's not like there's a TN panel of cameras if that's what you're worried about :P
3 minutes ago, L.Lawliet said:
How about some learning first before buy the camera..who knows u might need it..
Shutter speed in camera are expressed in those number basically the more the number the faster it is..
A fast shutter speed is needed to freeze moving object or even fast moving object..have u ever saw a pic of flying hummingbird that looks like this... they use high shutter speed to freeze the motion..
  Hide contents
Or a water that looks like silk? they use high shutter speed for this
  Hide contents
stock-photo-waterfall-of-a-river-with-a-
Great examples, deffinetly helps to know what that would matter for, luckily tax return isn't till about February, March time so I have a good long time to see what works for me. But learning now and seeing what I need will help for when the time comes around to purchase the camera.
Didn't think so, I've been trying to avoid computer processing for now, enough to get me by before the photos I am taking need to be color adjusted.
  Reveal hidden contents
*Low shutter speed?  Typo? :P
One thing I will say though, in case you're not aware, is generally the workflow goes something like this:
  1. Get home from shooting
  2. copy images to computer
  3. review images, deleting the vast majority or at least filing into a "nah not this" folder
  4. Going through the good ones one by one in lightroom/camera raw and then photoshop
you could just batch process them all with default settings but for the best results you'll want to set sharpening, highlights/shadows, black/white point, straighten, crop, etc. to make sure they're ideal.  Obviously you want to get them as close to perfect "in camera" but there can often be quite a bit of time spend on the PC as well, especially if you're doing portraits or something that typically gets a lot of retouching.
PS, this assumes you're shooting in RAW, not jpg, which is definitely how you should do it or you'll be wasting most of the potential of the camera.
Does the file type make that big of a difference?
Have you looked into mirrorless? I made the switch from DSLR and highly recommend it. The Sony a5100 would be an excellent choice.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
yes absolutely.  RAW is what it sounds like - the raw sensor data off the camera.  It isn't even technically an image at that point but the software will interpret it into one.  This will make use of the full 12 or 14 bit dynamic range, allowing for recovering of shadows, playing with exposure, colours, etc. in post without having to notice any loss in quality.  If you shoot jpg, not only are you flattening it to 8 bit right then and there but you're also compressing it (adding artifacts and reducing sharpness).
Yes. I like the mirrorless cameras better even though my experience was bad at first, but the new sony a series of mirrorless cameras made me drool. i now regret buying a t6i too fast. i find the a6300 or a6500 good for run&gun/ amatuer shooting and the a7rii a beast for stills and a7sii better for video.
I'm a fan of Intel
Yeah, I would seriously consider it, I shoot 4k Video on my a6300 for work and my point and shoot camera is the a7R II. I love both and could never go back to a DSLR, also Sony quality seems to have improved and I have had the a6300 for almost 2 years now with no issues and the a7R II has been solid too.
My Builds:
MEGA Desk Build
Just now, L.Lawliet said:
For photography people will avoid mirrorless camera simply because of the viewfinder.
Mirrorless is good for videography cause when u record a video u wont be looking at the viewfinder..and they are cheaper..
For example The panasonic G7 which is only about $600-700USD can shot 4k at 24fps..with DSLR u'll need to spend $1000 just for the body only..
But they avoid it out of pure stubbornness haha, I was the same way and tbh even though yes it was a change I at first was not keen on I no longer really miss it, if you are into super high-end photography I get it, but for 75% of people out there I think it would be a welcome change. I personally think it's worth the switch.
My Builds:
MEGA Desk Build
