1 minute ago, Josh83089 said:
If it's the same as the B150A as the current revision listed on MSI's website, it has an M.2 slot directly above the top PCIE x16 slot.
Interestingly enough, they show 2 stock photos on their page, 1 with an M.2 slot, and one without, so you may in fact have a different version, or they're using improper photos.
https://linustechtips.com/topic/849981-m2-adapter-for-mobo/#findComment-10594756
You can get a PCIe to M.2 adapter
https://linustechtips.com/topic/849981-m2-adapter-for-mobo/#findComment-10594758
That nvme compatibility bit may be about being able to boot from pci express ssd drives - you could then probably buy a pci-e adapter card with one or several m.2 connectors and it should work and boot from SSD.
Note however that not all M.2 SSD drives are using pci express to communicate with the PC, in fact a lot of the cheaper SSD drives simply use the plain old SATA 3 which is also included in some m.2 connectors.
So before spending more money to get pci-e based m.2 slots (or connectors. whatever) make sure you actually have a pci-e m.2 ssd.
for pci-e to m.3 i figure something like this would be enough, if nvme is supported in bios : https://www.newegg.com/Product/Product.aspx?Item=N82E16815124167
this one is a bit more fancy and also has a m.2 slot which routes the sata part of the m.2 slot into a sata connector (so you could use a sata cable between this card and the sata port on the motherboard) : https://www.newegg.com/Product/Product.aspx?Item=N82E16815256014&cm_re=m.2_pci-e_adapter-_-15-256-014-_-Product
https://linustechtips.com/topic/849981-m2-adapter-for-mobo/#findComment-10594769
