Hey guys, so my current rig has a GTX 770 in it (old I know but it still works great). I saw an ad on craigslist for some guy selling his 770 for $30, except that it "doesn't work". He claims that it "powers on and the fans spin" but doesn't output anything to the display. I'm due for a GPU upgrade but before I do that I'm really tempted to buy this and see if I can somehow make it work with my system in SLI, but do you guys think this is even possible? Is it worth the risk? I trust my technical troubleshooting capabilities but I don't have a ton of experience with dead cards. I like to think that since the fans still spin and it "turns on" that maybe he's just overlooking something with his system (Bios, Drivers, etc.), but I suppose it could just be dead. Has anyone experienced an issue like this before or have advice on whether or not I should risk the money on it? I'm a student so I don't have a ton of cash to throw at a new, more powerful card, so maybe this could work for me? Any advice or opinions would be appreciated. Thanks!
Meh some build specs...
Meh some inspirational quote meh...
https://linustechtips.com/topic/849546-help-with-gtx-770/
I wouldnt recommend buying it. In theory if it's just a damaged display output then you can SLI with it, but there's just too many possible faults that makes the card not output anything.
Desktop benching:
https://linustechtips.com/topic/849546-help-with-gtx-770/#findComment-10590207
Thanks for the reply! While I agree that there are lots of possible faults, do you think the fact that it still powers up matters at all or helps determine the issue? Faulty display output could potentially be solved by using a different output port right?
https://linustechtips.com/topic/849546-help-with-gtx-770/#findComment-10590215
offer him 5$ and try.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/849546-help-with-gtx-770/#findComment-10590222
I dont think so. Many types of internal damage just arent visible to the naked eye. Also working fans do not mean the card can still function as a graphics card.
Desktop benching:
https://linustechtips.com/topic/849546-help-with-gtx-770/#findComment-10590225
Thanks guys! @Jurrunio You're right the risk is probably too great. @GDRRiley I'll offer him $5 and see what he says, if he agrees I can potentially play around with it or have a nice paperweight at worst. :D
https://linustechtips.com/topic/849546-help-with-gtx-770/#findComment-10590237
Maybe go over and look at it quickly, don't fix it for him if you realise it doesn't work just say your a collector or something XD.
https://linustechtips.com/topic/849546-help-with-gtx-770/#findComment-10590257
Working fans but no display means a few things. Either:
Display ports are damaged
Traces to display ports are damaged
One or more of the solder balls under the GPU package for the display traces are damaged
The display circuitry in the GPU is damaged
So no don’t bother.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/849546-help-with-gtx-770/#findComment-10590319
Broken hardware isn't worth $30. Throw a $5 at him like was suggested and if he doesn't take it for that then hes dumb. No ones gonna buy it.
Currently majoring in computer networking. That's about it yeah. Not much goes on in my life.
Be sure to quote me if you want me to reply!
https://linustechtips.com/topic/849546-help-with-gtx-770/#findComment-10590326
