Bubbles in cooler?
Try changing the position of the radiator and leaving it for a few days to see if the bubbles stop.
You can also try tilting your case using books or something for a while until the noise stops.
You just need to try to trap the bubbles at the highest point of the loop.
https://linustechtips.com/topic/849491-bubbles-in-cooler/#findComment-10589657
Do you think its bubbles? Its like a buzzing sound like from a light bulb.
https://linustechtips.com/topic/849491-bubbles-in-cooler/#findComment-10589662
Yeah, probably microbubbles going through your pump.
Or it could just be the pump itself, sometimes the impeller isn't perfectly balanced and it causes vibration.
The bubble one is fixable, but the vibrating pump isn't.
https://linustechtips.com/topic/849491-bubbles-in-cooler/#findComment-10589664
A buzzing sound from a pump may mean that there's a bubble in the pump. If you're able to get the bubble to the rad, you should be good to go.
And please, just please tell me you're PC is off when you're shaking it.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/849491-bubbles-in-cooler/#findComment-10589681
Lol Ive seen people say both so I did it a little with it on but will do it the most with it off. Yea Its fine when theres no stress on the GPU
https://linustechtips.com/topic/849491-bubbles-in-cooler/#findComment-10589686
It's probably bubbles. If so, it should clear up after a few days once the bubbles make their way out/to the top of the system.
Less likely, but possible is the pump is running at max speed, might want to check your settings and see if you can drop the speed a bit see if it improves.
https://linustechtips.com/topic/849491-bubbles-in-cooler/#findComment-10589688
I think it might be a combo since it only happens when gpu is under some stress. Setting where?
https://linustechtips.com/topic/849491-bubbles-in-cooler/#findComment-10589732
The pump probably doesn't run or barely runs until its gaming which would be normal on GTX 980 and 1080 cards with good cooling.
Some manufacturers include software for overclocking and controlling fan/pump speeds. (Asus usually supply AI Suite/Fan Xpert, etc). If you're using an EVGA Hybrid though I don't think they include any controls so you might need to flash a ROM with the pump speed settings/voltages, but that's a bit complicated at this stage.
Assuming you have an EVGA 980ti Hybrid, I did some looking and a few people reported the sound but it went away after a few days. Others reported no change and RMA'd the card. http://forums.evga.com/980-Ti-Hybrid-Pump-Constant-Buzzing-Noise-RMA-m2361427.aspx
I'd give it a few days and see what happens first.
https://linustechtips.com/topic/849491-bubbles-in-cooler/#findComment-10589793
I bought it used and am assuming it didn't used to happen, so it should go away
https://linustechtips.com/topic/849491-bubbles-in-cooler/#findComment-10589874
