LG G6 finger print scanner
Solved by Light-Yagami,
Just now, BadluckBrian said:This is a new problem
Well, yeah that could work but the thing is... It worked in any position before. It could be upside down vertical horizontal and it would work. And I had my left pointer and middle finger scanned along with my right pointer and middle finger.
If hard resetting the phone doesn't work, try factory reset (I know it sucks, but it usually helps -.-).. If that doesn't do it, replace it. Warranty covers this kind of sh*t..
