Assuming the budget is in USD and it's just the PC...
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($199.89 @ B&H)
Motherboard: ASRock - Z370 Pro4 ATX LGA1151 Motherboard  ($111.98 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($77.99 @ Newegg)
Storage: SK hynix - SL308 120GB 2.5" Solid State Drive  ($52.99 @ SuperBiiz)
Storage: Hitachi - Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Amazon)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB GAMING Video Card  ($259.88 @ OutletPC)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($26.99 @ Newegg)
Total: $809.70
Generated by PCPartPicker 2017-10-20 10:08 EDT-0400
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10583440
country? need os/monitor/peripherals?
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10583443
6 minutes ago, tony249245 said:
best I5 you can get with that budget m8
Why i5? An r5 1600 would be good.
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10583564
https://pcpartpicker.com/list/KxH3r7 Thats a 800 dollar coffee lake build, it should treat your friend well.
Former Bronze Contributor
CPU: Intel i7-7700K 4.2 GHz / CPU Cooler: Cryorig H7  / Board: ASRock Z270 Taichi / GPU: Nvidia 1060 6gb EVGA SC / GPU Cooler: NZXT Kraken G12 with Thermaltake Water 3.0 120mm RAM: White Corsair Vengeance LPX 16GB DDR4 2666 MHz SSD: 2x Samsung 850 Evo 250 and 3TB WD blue HDD / PSU: Corasir 550cx / Case: NZXT s340 Elite White
Im a super Italian. Kapish.
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10583569
Please don't start with this. The op said he wanted an i5.
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10583575
Just now, tony249245 said:
ooooooooo i like that one nice gj <3
No problem my dude.
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10583603
bad psu, no stock for ram, unnecessary cooler and ssd capacity is too low.
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10583650
Not a bad PSU for the build, its a bronze 80+ PSU by EVGA,a very trustworthy PSU manufacturer.
The cooler inst unnecessary if you want low temps, plus Linus himself used a more expensive cooler on an i5-7500.
 The ssd is used as a boot drive and if the op wanted to he can upgrade.
RAM may be out of stock but there are other kits out there for the same price.
Thank you for your complaints, but next time perhaps show a bit more positivity instead of hating on someone who is giving a suggestion.
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10583738
ooof nice job man what do you think of the upgrades i did tho
https://pcpartpicker.com/user/tony249245/saved/RWkf8d
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10583742
I like it but let me give you my take. That is a very good power supply but personally you don't need a $60 dollar power supply. It's a bit overkill.
If your friend dosnt mind slow boot times than you dont need an ssd. Just stick a low captivity ssd in their, But in the end it's up to you.
Here is my final list to match your color scheme a bit more.  https://pcpartpicker.com/list/Kk8jm8
@herman mcpootis That's how you reply to someone suggestion, you just got schooled.
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10583785
EVGA does NOT make their own power supplies. they get other companies to make it for them and they slap their labels in. that BT uses low-end components and is only rated for up to 30 degrees at full power.
the stock cooler is enough for a locked i5 as long as it doesn't cause overheating. the money saved would have been far better off used on a 120gb ssd instead.
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10583865
26 minutes ago, tony249245 said:
i'd recommend you get the CX450M instead and use the stock cooler, use the money for an ssd to use as a boot drive. you'll see much better responsiveness and boot times with one.
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10583880
I didnt actual know that about EVGA, thank you. I personally use corsair anyway.
I always want to keep my parts cool, which is why I recommend the heat sink, but yes the stock cooler would work.
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10583915
Ah yes, because if Linus used it it must be good.
That build as a whole is just a horrible build, imo. The stock cooler is enough that it won't be excessively loud while providing decent temps. For a locked cpu, at most you need a $10-$15 cooler, but usually stock is enough.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10584327
I would expect you to know more. Highly disappointed.
That PSU is a piece of junk, would much rather get the $30-40 (or even $20 on sale) Corsair CX450.
Plus for no OC stock is fine
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10584481
Fair enough JDE.
But Seon dont be petty.
https://linustechtips.com/topic/848908-need-help-on-an-800-pc/#findComment-10584510
