QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/847997-looking-for-a-cable/#findComment-10573171
Just now, RadiatingLight said:
yes but I want the male ends and I want to separate the Left and Right sides. Its for recording. My cassette player has Mic left and mic right. I want to record from records and my computer(and others)
https://linustechtips.com/topic/847997-looking-for-a-cable/#findComment-10573177
oh, got it.
so instead of separating mic and headphone, you want to separate left and right
Laptop:
https://linustechtips.com/topic/847997-looking-for-a-cable/#findComment-10573185
You could use these things and plug the red one into the red one on one of them and the white one into the white one on the other
https://www.amazon.com/Mediabridge-3-5mm-Male-2-Male-Adapter/dp/B004YEBK66 x1
https://www.amazon.com/RiteAV-Stereo-Female-Adapter-Y-Cable/dp/B0018MI5F6 x2
https://linustechtips.com/topic/847997-looking-for-a-cable/#findComment-10573196
Only problem with that is it doesn't say if it's just splitting or if it's actually separating left and right
https://linustechtips.com/topic/847997-looking-for-a-cable/#findComment-10573216
3$ : 6ft Premium 3.5mm Stereo Male to 2RCA Male 22AWG Cable (Gold Plated) - Black  : https://www.monoprice.com/product?c_id=102&cp_id=10218&cs_id=1021815&p_id=5598&seq=1&format=2
PAIRED WITH
2 x 0.28$ : 3.5mm TS Mono Plug to RCA Jack Adapter, Gold Plated  : https://www.monoprice.com/product?c_id=104&cp_id=10429&cs_id=1042902&p_id=7146&seq=1&format=2
OR
0.44$ : 3.5mm TRS Stereo Plug to 2x RCA Jack Splitter Adapter, Gold Plated  (female RCA) : https://www.monoprice.com/product?c_id=104&cp_id=10429&cs_id=1042902&p_id=7189&seq=1&format=2
0.22$  : 3.5mm TRS Stereo Plug to 2x RCA Plug Splitter Adapter, Gold Plated  (male RCA) : https://www.monoprice.com/product?c_id=104&cp_id=10429&cs_id=1042902&p_id=7199&seq=1&format=2
PAIR it with   2 x  RCA female to  TRS mono cable (from somewhere)
OR whatever combination you can think of  while moving through an intermediary connector like the classic RCA for example.
https://linustechtips.com/topic/847997-looking-for-a-cable/#findComment-10573274
