Just now, EnoFC said:
CPU: i5 7600k @ 3.80ghz (not overclocked)
Mobo: H110m-a gigabyte
Memory: 8gb ddr4
Graphics: GTX 970
250gb ssd, 800gb hard drive, windows 10 home
Not suppose to be an extreme build.. just for casual and smooth gaming. Maybe upgrades in the future.
I like it. Beats me system?
don't get an unlocked cpu and pair it up with a H110 board. get a ryzen 1600 and b350 board instead.
Getting the 1600 saves cash on a cooler too. Wraith spire is real good.
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
I was thinking later on in the future maybe a z170 mobo and overclock it?
i won't recommend it. the ryzen 1600 will perform better for around the same price and you can overclock it with a cheap b350 mobo.
Ok thanks i'll keep that in my notes and will swap it with a ryzen 1600 later on.
Long term, you will also save money on motherboards if you update your ryzen cpus with coming generations as opposed to doing the same with Intel. What I've heard is that AM4 is here to stay for years.
My PC:
Memory: 8gb ddr4
Graphics: GTX 970
Don't do this. That is basically the equivalent of an i3 8100 which is like a 120 dollar cpu. Much better off getting a z370 motherboard and a i3 8100 if you want to have a upgrade path. Otherwise you could go ryzen as well for a good platform with longer support.
2020.
Memory: 8gb ddr4
Graphics: GTX 970
Also why the gtx 970? Are you buying all this used?
Idk why everyone is recommending Ryzen. It seems to me OP already has this system.
OP- there are some really weird components and you could have definitely done better, but its a perfectly fine system.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
Memory: 8gb ddr4
Graphics: GTX 970
Have you already bought this or are you just planning on doing so?
Z170 motherboards are getting rarer and more expensive.
Ryzen needs a different motherboard.
