Enough power to two GTX 960's and a fast SLI bridge?
NTDaws
What is the fastest SLI bridge for a gtx 960 if someone could link me one.
Got a free 4gb gtx 960 to put beside my other one.
Also will 550watts G3 EVGA power supply do the job?
The geek himself.
Yes most definitely, it is a 120W TDP Card. But the SLI Elitists will say you need 1000W just to be safe.
Inb4 people that say don't SLI it.
Go for it it was free.
550 might do the job depending on the rest of your specs.
shouldn't matter what SLI bridge you choose most of it is just quality control, Brand, Design.
go for one that is trusted and you like and you'll be fine.
a 550w is more than enough
afaik, all SLI bridges are created equal; just buy the least expensive one
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
tdp =/= power consumption
rip
No duh. But it's something to base it off of. Relax my dude.
Model Idle Gaming Torture Power Target
Nvidia GTX 960 Reference (Emulated) 10W 85W 119W 120W
Asus GTX 960 Strix OC 7W 100W 144W 130W
Gainward GTX 960 Phantom OC 7W 100W 133W 140W
Galax/KFA² GTX 960 EX OC 11W 90W 119W 120W
Gigabyte GTX 960 WindForce OC 11W 97W 165W 160W
Gigabyte GTX 960 Gaming G1 15W 108W 170W 160W
inno3D GTX 960 iChill 9W 98W 162W 160W
Palit GTX 970 Super JetStream 10W 108W 133W 140W
Not really.... there are the basic single finger ribbon cables for traditional SLI... there are the rigid dual finger stiff bridges which are often just aesthetic purposes with nice designs/LEDs on them, but they're actually slightly faster/more efficient for operating at higher fps/resolutions with fewer issues, then there are the HB bridges released when Pascal was released which are all dual finger stiff bridges but are designed to operate at even higher framerates/resolutions.
@Being Delirious So beyond those 3 types of bridges, there isn't really a "fastest"... the EVGA bridges are no faster than the Asus bridges or Asrock bridges or whatever. Considering you have 960's you can't hope to push the kind of resolutions and refresh rates needed to warrant anything other than the standard single ribbon cable bridges which come with most motherboards. That being said, if you truly want the "fastest", get yourself an HB bridge which looks nice and call it a day.
these only really madder for high end and pascal
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
HB won't fit so anything below LED will work, im only playing at 1080p anyways.
The geek himself.
Just now, Zyndo said:
Not really.... there are the basic single finger ribbon cables for traditional SLI... there are the rigid dual finger stiff bridges which are often just aesthetic purposes with nice designs on them, but they're actually slightly faster/more efficient for operating at higher fps/resolutions with fewer issues, then there are the HB bridges released when Pascal was released which are all dual finger stiff bridges but are designed to operate at even higher framerates/resolutions.
this table is only applicable to Pascal cards, not Maxwell ones
not at all. this information is equally relevant to previous generation stuff as well.... its just that previous generation stuff likely isn't powerful enough to leverage those kinds of refresh rates or resolutions, and with more widespread support for 3-way and 4-way SLI the "standard" flex bridge was about the only option since you needed to link the cards 1 finger at a time to the card next to it, rather than using both fingers like the LED bridges and HB bridges use (resulting in more bandwidth for higher performance). these inadequate flex bridges were also much of the problem for why there were so many issues with 3-way and 4-way SLI (apart from it just being terrible on its own) thus the declination of support for that feature.
Sure.... but the OP did say "fastest" which would mean HB bridges, and I was mostly making the comment to correct @shadowbyte so that someone else who is perusing this forum doesn't see his misinformation and take it as fact.
Just now, CUDA_Cores said:
real question is why you want to SLI GTX 960s in the first place.
has 1+ 1 free
i.got.them.for.free.bruh.
The geek himself.
sell em and get a single more powerful card.
fucc dat experiments for the win
The geek himself.
SLI 960 it is then. You don't argue with another mans experiments.
Also you probably will be able to do it on that PSU.
alright thx m8
The geek himself.
4 minutes ago, Being Delirious said:
alright thx m8
what cpu btw. cause they also consume power. i9 for example consumes a lot
alright thx m8
a
rip
16 hours ago, Dan Castellaneta said:
how the hell did you wind up with a free 960
I can't even find modern computers here that are used and cheap
my friend said fuck it.
The geek himself.
tell us what benchmark you can get out of it :)
not many people run sli 4gb 960's I'd love to see what it could do!!!
will do
The geek himself.
