Posted October 15, 2017 Hi I want to buy a new access point and there is 2 models I can choose from one has 400ft range and the other has 600ft range. I itened to use 1 on the top floor to reach down to the 3rd floor through concrete and brick walls. Which 1 should I go for. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 15, 2017 Either, i would go with multiple access point on each level for the best performance. You could grab Ubiquiti Lite Access Point for around 100 dollars each and place them on each level or just get two for other two level where you original router is at. Plus you need to give use model number, as marketing information in 99% of times is in Best conditions (no walls, no interference) . Magical Pineapples
