first build
Solved by seon123,
What will the PC be used for?
As for general advice:
Don't get the 1600X. Get the 1600 and overclock it.
A water cooler is unnecessary for a 6 core Ryzen. A decent air cooler will do just fine.
MSI males overpriced and mediocre motherboards. The B350 Strix would be as good. If you will get an 8 core, get something like the Prime Pro, Gaming 5, Strix or Taichi.
Get a cheaper RAM kit. You can easily get a cheaper 3000 or 3200 MHz kit.
Don't get an NVMe SSD, unless you will actually benefit from it. For normal tasks, like starting programs and Windows, it won't make a difference.
Get a cheaper or higher capacity HDD.
The Armor cooler is insufficient for a 1080 Ti. Get a card with a better cooler.
