unless its dumping a shit tone of heat into your case or has the shitties 12V out in history that shouldent really be impacting the temps here
Builds:
https://linustechtips.com/topic/846579-evo-lab-750-psu/#findComment-10557555
1 hour ago, Pengu1N said:
the psu shouldn't affect gpu temps... maybe you wired the gpu wrong or something idk
If it is shitty enough, it does however due to high ripple.
@Roadrunt It seems its one of those overrated, low(est) Quality things that will kill your components and maybe even you, the only question is when.
So it's not a good idea to use it.
This PSU is just enviromental Pollution because it serves no purpose other than a Paper Weight. Or maybe, if you really have to, you can defend yourself with it.
But other than that it shouldn't be used.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/846579-evo-lab-750-psu/#findComment-10557750
