SLI not changing performance?
21 hours ago, Frankenburger said:Hard to say since surround with SLI isn't all that common, and I retired my old 3x 1080p setup a while ago. Testing a more common resolution such as 4k would give a better idea if SLI is working. If you test again with SLI disabled, do your frames drop while in surround configuration?
On 10/13/2017 at 9:48 PM, Mick Naughty said:Technically you don't have sli enabled if you are using surround but you should still notice the improvment run a benchmark with and without once card. Would be pretty clear if it's a game issues or something else.
So I disabled SLI and did the benchmark again and the results are:
Average FPS: 58.8
Max FPS: 129.3
Min FPS: 25.9
These results were very weird so I did another benchmark with SLI enabled and the results are:
Average FPS: 102.7
Min FPS: 32.2
Max FPS: 178.0
For some reason when I re-enabled SLI the results are different from my first results........ I guess some how that SLI was disabled on the first results and on the second benchmark thats when SLI was enabled? Idk.
