motherboard smoking sometimes and cpu overheat HELP!
Solved by epic_ziver_D,
It might be water evaporating from the wet rag, altho I am not sure. Please show pictures. Also if you havent make sure you turn off the pc and unplug it.
EDIT: if you are trolling then just don't...
Share
Followers
1
