I mistakenly cleaned my whole file.now there is only one drive and no data. please tell me how to get it back.
tried to install win 10 then it said error when I tried to format the C drive,then I googled and find a solition where I need to clear the disk from boot.and now I cant dp amything.there is no file no wiindows nothing.
the link o followed
please tell me what do to
p
https://linustechtips.com/topic/843146-please-help-me/
so you nuked your main windows boot drive?
reinstalling will make matters worse
when reinstalling it will format the drive for installation and you have little chance of getting the files back
get another PC and use a recovery software to extract the files
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/843146-please-help-me/#findComment-10522338
7 minutes ago, Reallifecat said:
I'm pretty sure there are linux distros that run off a usb that recover data
Any idea what dristibutions?
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
https://linustechtips.com/topic/843146-please-help-me/#findComment-10522354
I think these:
http://www.livecd.com/
https://www.runtime.org/data-recovery-live-cd.htm
Not sure about this one: http://www.system-rescue-cd.org/
"What am I even meant to put here?" - Me 2016
https://linustechtips.com/topic/843146-please-help-me/#findComment-10522377
34 minutes ago, Reallifecat said:
Thanks a lot mate, I needed one of those more than once in the past and never bothered to lookup.
https://linustechtips.com/topic/843146-please-help-me/#findComment-10522439
You’ve already made posts about this. What is on the drive? Do you need anything on it?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/843146-please-help-me/#findComment-10522445
