Greeting fellow browsers of the internet,
I have recently procured a PC for 700 AED or 190.60 USD or 237.67CAD. I know that the computer works i was just having a problem figuring out what cables i need for it. The Previous owner listed it with these specifications:
Processors:: 2 Intel Quad Core Xeon X5482, 3.20GHz,24MB Cache, Processors
RAM:: 24GB ECC Fully Buffered RAM, Support up to 64GB,
Graphics:: 2 Professional Nvidia Quadro FX 3700, Graphics, Multi Display, HDMI Output
Storage:: 300GB, Fast 15000 RPM, SAS + RAID Controller
PSU:: Powerful 1000 Watts Power Supply
Networking:: Fast Gigabit Ethernet
OS:: Windows 7 Professional 64 bits
Audio:: High Definition Audio
Case:: Monster Dell Casing
Cooling system:: Air Pressur Cooling system
Input:: Dell Keyboard & Mouse
Optical Drive:: DVD Writter
Model:: Dell Precision T7400 Workstation
DIMENSIONS
Width 8.5 in
Depth 22.3 in
Thus I have turned to you kind people (of which i can only assume so) to hopefully help me with my crisis.
Thank you, regards
-Ali
https://linustechtips.com/topic/841058-help-me/
the DIV cable you posted should work fine
Builds:
https://linustechtips.com/topic/841058-help-me/#findComment-10498323
could you take 1 of the gpu's out, and test them one by one? those gpu's are nearing 10 years of age, it's possible one of them has failed.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/841058-help-me/#findComment-10498343
