GPU FAN NOT SPINNING
Just now, DriZyo said:I just turn on the pc and gpu fan not spinning with appear check video cable. I already plus my thermal with cm ice fushion. I can enter the windows sometimes. If i can get in and i started install my gpu the pc will crash and i must restart and not will get to windows again. what must i do if i can get in? reinstall gpu, reinstall mobo? or else?
Ah, that's a different issue. If your PSU uses external PCIe power connectors, make sure they're securely snapped in and, if modular, snapped into the PSU securely as well. You might also want to dismount and remount your graphics card to the motherboard to rule a bad connection out.
If that doesn't work, try a different port on the card and see if you get a signal off of it. This sounds less like a fan dying and more like a card dying.
