I have a ton of data stored on a 3TB Seagate Backup+ Drive that have been using connected to a nighthawk router as a network storage. My router failed and I was forced to get a new one, upgraded to Google WiFi which of course doesn't have the ability to network a drive to it. When connecting to my windows desktop via USB 3.0 the drive is no longer seen as an accessible volume. It can be seen in Disk Management but it is not showing a file system and will not let me assign a drive letter to it. I have verified that all my data is still on the Drive via the Seagate recovery software. My primary question is. how do I regain access to the data on that drive? I was able to access the data from the same computer when it was networked in. I really would love NOT to spend the 80 on the license to recover the data. Thank you in advance!
i5-7600k
ASUS ROG STRIX Z270G Gaming
2 x 8GB Corsair Vengeance LPX
Samsung 960EVO 256GB M.2
WD Blue 1TB
Gigabyte GTX1080 G1
Corsair CX750M
https://linustechtips.com/topic/838872-help-please/
Some one probably has a better solution than I do, but whenever I try to recover files on a volume that Windows cannot access (whether it's corrupted or something), I often find my self using Linux (I personally use Ubuntu just because it's nice and easy) as it seems to be able to handle messed up file systems much better than Windows.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/838872-help-please/#findComment-10475788
I have 0 experience with Linux. Will i be able to fix the drive so the data is accessible in windows? I currently don't have a volume large enough to store my data (entire movie library) if i have to recover and migrate.
https://linustechtips.com/topic/838872-help-please/#findComment-10475881
