i have a column called ID in my table and i have set it to increase by 1 when new data is inserted. when i inserted data like 3 times the ID was 3 but when i added another record instead of showing the ID as 4 it showed 6. i checked my auto increment settings and it was set to increase by 1. i didnt understand what was happening so i dropped the table, made a new one and started entering data. the first time i entered the ID was one but the second time i inserted it showed 4 as ID and the third time in inserted a record ID was 6. what is actually going on? im inserting data using the edit table data mode in sql server however the first time i tried it was using C# and i got the same issue. is this some error in sql server 2014 or am i doing something wrong?
https://linustechtips.com/topic/838683-sql-server-auto-increment-id-problem/
did you delete any rows? The database auto interment keeps a track of them.
1. Data
2. Data
3. Data
del 3, 2
4. Data
at the end the ids would be 1,4
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
1. Data
2. Data
3. Data
del 3, 2
4. Data
no, i inserted only and it came like that.
Just now, Lumi said:
I don't see why this is even an issue. It's probably because you removed some rows. SQL keeps track and continues the increment.
i didnt remove any. when i added a new row the ID automatically generated to that shown in the images.it happened twice now.thats why i decided to ask here
Then not a clue, but if its not going to break a system, which it shouldn't I wouldn't worry ti much.
i want to use that ID for a calculation and if they r not in correct numbers i will have trouble displaying the next record in my application
maybe you should find a new way then, as said the auto increment doesnt always have the last number but the last number of record.
Is your insert in a loop that closes and reopens the connection by chance?
i want to die
