2 minutes ago, lee32uk said:
You would be better going for a Ryzen R7 1700 for streaming. Do you really need 32GB Ram ? Also an 850W psu is enough for SLI.
Im not a amd fan so i want intel :( doing 32gb just if i want to run minecraft server and game. yea i know that the 1000w is a bit over kill
https://linustechtips.com/topic/838654-vr-ready-and-4k-build/#findComment-10473438
1 minute ago, erik.ham said:
yea im thinking about some streaming
Don't buy kaby lake.  Coffee lake is on a different platform and ryzen already dominates intel in streaming so you can either have to wait longer to spend more on coffee lake ( :( ) or buy ryzen now and save money
https://linustechtips.com/topic/838654-vr-ready-and-4k-build/#findComment-10473452
I will wait for the Coffee i really want intel :/
https://linustechtips.com/topic/838654-vr-ready-and-4k-build/#findComment-10473461
So if i go Ryzen R7 1700 will it be good?
If you go ryzen 7 now, you will save money over both kaby lake and coffee lake, but since no reviews are out, I don't know if it is BETTER than coffee lake, but I do know that ryzen 7 is better at streaming than intel's i7 kaby/skylake
https://linustechtips.com/topic/838654-vr-ready-and-4k-build/#findComment-10473475
Just now, hconverse02 said:
If you go ryzen 7 now, you will save money over both kaby lake and coffee lake, but since no reviews are out, I don't know if it is BETTER than coffee lake, but I do know that ryzen 7 is better at streaming than intel's kaby/skylake
okey Ryzen R7 1700 or Ryzen R7 1700x? what do you think? :)
https://linustechtips.com/topic/838654-vr-ready-and-4k-build/#findComment-10473484
Overclocked, the non-x series of ryzen performs the same as the x series of ryzen. The x series is just basically overclocked out of the box, and you can push it a little bit, butnot much further.  See 13:00 in the video, Jay says that ryzen doesn't come close to the professional workflow of r7 1800x (obviously not the 1700).  The difference in games is subtle but ryzen is beaten by intel.  In workflow applications, intel on dominates in single-threaded performance.  Ryzen is overall better for streaming/workflow where intel gets it done, but has better game performance.
Personal preference at that point
https://linustechtips.com/topic/838654-vr-ready-and-4k-build/#findComment-10473496
