Wi-Fi Card For PC
Go to solution Solved by BlackHoleFox,
Something like this would work for your friend.
http://a.co/bc6miXb
So my friend has this motherboard, https://pcpartpicker.com/product/2pnG3C/gigabyte-ga-ab350-gaming-3-atx-am4-motherboard-ga-ab350-gaming-3, and he wants a Wi-Fi and Bluetooth PCIe card. He will need 802.11ac for 5GHz wifi and the Bluetooth for Xbox controllers and etc. He will have around 60 US $. It can fit in the available 1x and 16x PCIe slots, top 16x is taken by a GPU. He will need something that can do 300MB/s Megabytes per second.
https://linustechtips.com/topic/838640-wi-fi-card-for-pc/
http://a.co/bc6miXb
Agree with blackholefox and just for your terminology I think you mean megabits (mbps), not megabytes (MB/s) 100mbps is 12.5 MB/s, most internet providers use mbps, but people who dont know as much think it is megabytes and with 100mbps they think they can download a movie in 10 seconds. Kind of a scam imo, but welp
subscribe to pewdiepie
https://linustechtips.com/topic/838640-wi-fi-card-for-pc/#findComment-10473344
he will also be using this to access NAS and other lan stuff like Xbox streaming to Win10
he only has 45Mb/s on speedtest...
https://linustechtips.com/topic/838640-wi-fi-card-for-pc/#findComment-10473348
You're not going to find that wired. The card listed above uses an Intel 8260 wireless m.2 card on it, and that's one of the highest end wifi cards available, but it *still* can't do 300MB/s
The 8260 on wireless AC, with a matching AC router, with no other clients, with a perfect connection to the router, with 2x2 MIMO streams, before overhead, tops out at 867Mbps. That's Megabits, not megabytes, so 108MBps. And that's in perfect conditions.
You'd need a 10GBps wired NIC to get 300 MBps.
https://linustechtips.com/topic/838640-wi-fi-card-for-pc/#findComment-10473371
So he wont be able to do transfers via wifi only his gigabit eeros.
https://linustechtips.com/topic/838640-wi-fi-card-for-pc/#findComment-10473374
