Bought my H110 over 4 years ago (i know, not that old). I've read there is no maintenance required, but i just wanted to hear what you guys think. Does the performance ever degrade? How much longer does it have? Anyone do maintenance on theirs besides dust cleaning? (I.E flushing fluids, refilling, etc)
Rig
CPU: 4770k @ 4.2GHz 1.15v | Mobo: ASUS z87 Sabertooth | Cooler: Corsair H110 | RAM: Vengeance 32GB DDR3 @ 1600MHz | GPU: GIGABYTE G1 GTX 1070 | Storage: Samsung 840 series 250GB SSD, Seagate 2TB SSHD, Seagate 4.25TB HDD | PSU: Corsair AX850 80+ gold modu | Case: Corsair 650d | Keyboard: Corsair K65 RGB Cherry MX Reds & a Leopold 210TP Numberpad Cherry MX Blues | Mouse: Logitech G502, DECHANIC desk mat | Monitor: 2x Dell IPS 23" S2340m & ASUS 144hz 24" VG248QE | Speakers: CA-3602a | Headset: Steelseries Syberia v2 Frost Blue OS: Win 10 Pro
https://linustechtips.com/topic/836008-aio-maintenance/
Do you see any performance degradation? If not, then no maintenance is needed.
I don't believe you could perform maintenance even if you wanted to, since it wasn't designed with that in mind. They're so cheap that you'd just go out and buy a new one.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/836008-aio-maintenance/#findComment-10445190
You can't refill them.
All you can do is clean out the dust from the rad and replace the AIO if it fails.
I've had  my H100i for like 6 years now or something crazy like that, still working fine.
https://linustechtips.com/topic/836008-aio-maintenance/#findComment-10445235
Cool, i dont see any degradation in temps. I guess i just wanted to stay proactive in preventing any type of failures, but i guess with these AIO's it's kinda inevitable after awhile. Might switch to a beefy air cooler sometime in the future after mine goes out and not worry about failing pumps ever.
Rig
https://linustechtips.com/topic/836008-aio-maintenance/#findComment-10445263
some come with drain ports like some of the deepcool systems have them. i always assumed u could refill them. or do what jesse at jpmodified does and just cut the tube and do it by hand with new tubing :P
Faith: WIP
Cpu: intel 6700k
RAM: g.skill ripjaw v 3200mhz 16 18 18 38 2n 32gb 4x8gb
MB: Asrock extreme 7+
GPU: GTX 1080 TI Poseidon Platinum Asus ROG
PSU: Cougar 1050W 80+ gold
Case: IN WIN 509 ROG [ black red ]
Cooling: Barrow Fittings, Block, 360mm x 60mm rad, 18w d5 pump, 210 res, EK blood red premix. Poseidon GPU block
SETUP: BenQ 27" 144hz|BenQ 28" 1080p VA 60HZ|Corsair Strafe RGB|Razer DeathAdDer Chroma|ATH IM70|E10k Olympus 2 amp|DX Racer King
https://linustechtips.com/topic/836008-aio-maintenance/#findComment-10451217
Those are not regular AIOs, those are expandable AIOs, and in general almost all of them suck.
If you cut the tubing and replace it then you should also start saving up to replace all your components when they die from a leak.
https://linustechtips.com/topic/836008-aio-maintenance/#findComment-10451237
