Hey, does anyone know of a mouse that will fit under being: ergonomic, adjustable led color, optical, has a clawgrip style size, and great for fps games. I dont care much about the price, just as along as it has all these characteristics.
https://linustechtips.com/topic/83538-need-help/
Perfect one right here
$T2eC16V,!ysE9sy0iOo!BR3g+I7+FQ~~60_35.J
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/83538-need-help/#findComment-1137869
https://linustechtips.com/topic/83538-need-help/#findComment-1137990
Especially for mice I would recommend going into a electronic store and actually holding them in your hand. Everyone is different. For example my best bud bought a Cyborg R.A.T. 7. He loved the mouse and so I tried it out. I could not get comfortable with it to save my live.
My point here is, go into a mall, touch the mice and compare the once you like online. If you know what fits your hand or you feel comfortable with you can come back and we can check specs but no one can tell you which mouse is ergonomic :)
Will this work with my Apple I though? :D
I7-4770k - ASUS Maximus VI Formula - 16GB ADATA 2133MHz - EVGA 780 SC - 512GB Intel SSD - 2TB WD Black - Thermaltake DPS 750W
https://linustechtips.com/topic/83538-need-help/#findComment-1137991
I heard that the deathadder has a short clicking distance enabling one to have a quicker response time especially in fps, but it has a palm grip style to it and has a fixed green led light. i saw a review on perixx mx-3000 and that mouse has a really low clicking distance. Kind of like a trigger stopper in console controllers.
https://linustechtips.com/topic/83538-need-help/#findComment-1138758
Please make your spoiler smaller or use spoilers to make them smaller.  It takes up a lot of space and is distracting.
Quote my post to see how to do this
As for the mouse, check out the logitech G9x: http://pcpartpicker.com/part/logitech-mouse-910001152
@Apathy You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/83538-need-help/#findComment-1138764
